[gdal-dev] GDAL warp tutorial question (C vs. C++)
Even Rouault even.rouault at spatialys.com
Tue Apr 5 03:47:42 PDT 2022
Le 05/04/2022 à 01:28, Michael Sumner a écrit :
> Hello, the warp tutorial  needs at least inclusion of "cpl_conv.h" for
> CPLMalloc to work.
> https://gdal.org/tutorials/warp_tut.html
> But, I'd like to ask why it uses the style of the C examples (as per
> the Raster API tutorial
> https://gdal.org/tutorials/raster_api_tut.html) rather than the C++ -
> i.e. it uses 'GDALDatasetH hSrcDS' declarations rather than
> 'GDALDataset *poDataset', and all the 'GDAL<Functions>' rather than
> '->' pointer syntax.
> Is that recommended, or is it just old style in this tutorial (because
> the apps were originally C)?
Probably just the preference of the author of the example. At least the
first code snippet
(https://gdal.org/tutorials/warp_tut.html#a-simple-reprojection-case)
uses some C++ with the GDALWarpOperation class so it could be
potentially converted to full C++ (but you'll need to keep CPLMalloc()
and not use new[] because GDALDestroyWarpOptions() expects panSrcBands
and panDstBands to have been allocated with CPLMalloc())
Actually I see the second snippet
(https://gdal.org/tutorials/warp_tut.html#creating-the-output-file) does
use some bits of C++ with the OGRSpatialReference class. It could be
either fully converted to C++ (but some functions like
GDALCreateGenImgProjTransformer() or GDALSuggestedWarpOutput() only
exist in the C API, so you'd have to cast C++ dataset objects to C
handles at some point. This also applies to the first snippet, which
explains that using C functions is more practical to avoid those casts))
or C.
http://www.spatialys.com
