[gdal-dev] gdal_translate drops XMP exif tags
Tom O'Reilly oreilly at mbari.org
Mon Aug 8 13:16:14 PDT 2022
Hi Javier,
As noted in my previous response, I was wrong about gdal_translate - it actually does transfer the XMP tags from the input to the output, as XMP tags.
It is a subsequent call to gdalwarp that drops the XMP tags.
I am running gdal 3.5.0
Thanks
Tom
Thomas C. O'Reilly
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, California 95039-9644
831-775-1766 (voice)
831-775-1620 (FAX)
oreilly at mbari.org (email)
http://www.mbari.org (World-wide Web)
"The machine does not isolate us from the great mysteries
of nature, but plunges us more deeply into them."
- ANTOINE DE SAINT-EXUPERY
"Wind, Sand, and Stars" (1939)
From: "Javier Jimenez Shaw" <j1 at jimenezshaw.com>
To: "Tom O'Reilly" <oreilly at mbari.org>
Cc: "gdal-dev" <gdal-dev at lists.osgeo.org>
Sent: Monday, August 8, 2022 12:03:39 PM
Subject: Re: [gdal-dev] gdal_translate drops XMP exif tags
Which version of GDAL are you using?
in [ https://gdal.org/programs/gdal_translate.html | https://gdal.org/programs/gdal_translate.html ] there is an option, "-noxmp", since GDAL 3.2. Without that option it should keep them. If I remember correctly, the XMP tags are copied as proper XMP, not as GDALMetadata, with TIFF files.
An example with "gdalinfo -mdd all" for input and output may help.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 8 Aug 2022 at 20:32, Tom O'Reilly < [ mailto:oreilly at mbari.org | oreilly at mbari.org ] > wrote:
gdal_translate output .tif file does not contain XMP tags that were present in the input .jpg file.
The output file contains many of the input EXIF tags, aggregated as the GDALMetadata tag, but not the XMP tags.
Why does gdal_translate remove XMP tags - is there an option to preserve them?
Thanks
Tom
Thomas C. O'Reilly
7700 Sandholdt Road
831-775-1620 (FAX)
[ mailto:oreilly at mbari.org | oreilly at mbari.org ] (email)
[ http://www.mbari.org/ | http://www.mbari.org ] (World-wide Web)
gdal-dev mailing list
[ mailto:gdal-dev at lists.osgeo.org | gdal-dev at lists.osgeo.org ]
[ https://lists.osgeo.org/mailman/listinfo/gdal-dev | https://lists.osgeo.org/mailman/listinfo/gdal-dev ]
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220808/dfbf773c/attachment-0001.htm>
