[gdal-dev] question for scaling default
Michael Sumner mdsumner at gmail.com
Sat Aug 13 23:07:42 PDT 2022
Hello, I have a new driver candidate, it's natively a type Byte and is a
percentage (or fraction) floating point value when unscaled.  I have a
couple of questions. .
https://github.com/OSGeo/gdal/pull/6183
I'd like to have it unscale by default, with band type Float32 - but be
able to opt out of scaling, and return the raw Byte type. I think that is a
good default since most usage will want the fraction value, but
occasionally useful to obtain the raw codes that include some special out
of range values (>255).
I think I can work out how to do this, but is there a driver that already
provides this kind of behaviour that I can learn from?
Also, I feel like fraction (0, 1) is a more sensible data value than
percentage (0, 100), although I've used percentage in the past with these
data. Any thoughts, or examples that exist in GDAL?
Thanks very much, Mike
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220814/788b28a9/attachment.htm>
