[gdal-dev] Failing to write to s3 using GTiff driver.
Even Rouault even.rouault at spatialys.com
Tue Aug 16 06:05:16 PDT 2022
William,
>     COG: Generating overviews of the imagery: start
>     S3:
>     GetFileSize(https://my-bucket.s3.amazonaws.com/test_batch_output/test.tif.ovr.tmp)=0
>      response_code=404
>     S3: /vsis3/my-bucket/test_batch_output/test.tif.ovr.tmp is not a
>     object
>     GTiff: File being created as a BigTIFF.
>     ERROR 1: Only read-only mode is supported for /vsicurl
>     COG: Generating overviews of the imagery: end
>     S3: UploadId:
>     Rok8InTcYwFMoHYA3kVAwlLDycIxreczdLSODBpLA5exAshfS46ZclK.3.2.a_EAAY3vhoJQnc7DsVk9X3pzsRetSAZ.oc39kDwRe755ftroj5rH9BRXLPaNCcnuTGZP
>     S3: Etag for part 1 is "52647419376831771b40964bad80d86e"
>     S3: Etag for part 2 is "4bea862d0878bbe1dbe717aa8cea48c8"
>     S3: Etag for part 3 is "5ba3c9e4ea924f06cdc2ee614e5627c0"
>     S3: Etag for part 4 is "07e53a2e07a2575d1b2d89cf8040ebe8"
>     GDAL:
>     GDALClose(/vsis3/my-bucket/test_batch_output/test.tif.warped.tif.tmp,
>     this=0x55a288913060)
>     S3:
>     GetFileSize(https://my-bucket.s3.amazonaws.com/test_batch_output/test.tif.warped.tif.tmp)=207439264
>      response_code=206
>     GDAL: GDALClose(/vsis3/my-bucket/dtm/test.tif, this=0x55a2882e8570)
>     GDAL: In GDALDestroy - unloading GDAL shared library.
>  It looks to me like gdal attempted to write a lot of the tmp files to
> s3, rather than locally? the command I used is:
Yes exactly this is an issue with the temporary file created when
computing overviews, before integrating them to the final COG file. I've
tracked this issue at https://github.com/OSGeo/gdal/issues/6205 . I
should be able to look at fixing that soon
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220816/8fc15226/attachment.htm>
