[gdal-dev] Motion: Approve Even Rouault as a contracted GDAL maintainer for 2022-2023
DeTracey, Brendan Brendan.DeTracey at dfo-mpo.gc.ca
Sat Aug 27 07:09:55 PDT 2022
I am simply an occasional GDAL/GIS user. However, I would like to thank Even publicly because the few times over the past decade that I have had issues (one of which lead to a _very_ minor bug fix), he has always taken the time to helpfully reply.
Regards,
Brendan
Brendan DeTracey
brendan.detracey at dfo-mpo.gc.ca
(902)426-9727, VS 203/2-3
If you have received this communication by mistake, please notify the sender immediately and delete the communication without printing, copying or forwarding it. Thank you.
Si vous avez reçu cette communication par erreur, veuillez en aviser l'expéditeur immédiatement et la supprimer sans l'imprimer, la copier, ou la faire suivre. Merci.
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Howard Butler
Sent: Saturday, August 27, 2022 09:43
To: gdal dev <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] Motion: Approve Even Rouault as a contracted GDAL maintainer for 2022-2023
Dear PSC,
It has come to my attention that Even's term as a GDAL Maintainer officially ended 31 JUL 2022. I propose that we extend him for another year from 01 AUG 2022 to 31 JUL 2023 under the previous terms and conditions.
Although a small formality, we should make sure to keep a small bit of process around these things.
/me starts with +1
Howard
PS, expect a GDAL Sponsorship Annual Report next week.
