[gdal-dev] File Size Output is wrong --
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Dec 12 09:39:28 PST 2022
gdalinfo of the three files (two inputs and one output) may help to
understand better the conditions.
One option is that file A is not compressed, while the output is LZW.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 12 Dec 2022 at 17:47, Clive Swan <cliveswan at gmail.com> wrote:
> Greetings,
> I am writing the output on the local AWS Instance to avoid write
> permissions error, then copying to a Bucket.
> I get an error message if I leave out --config GDAL_SWATH_SIZE 1000000
> I want to merge File A into File B, updating the 6GB file. The output is
> 622MB NOT 6GB??
> (A) /vsis3/summer/1/coastal-2020.tif  = 6GB
> (B) /vsis3/summer/2/coastal-2020.tif  = 622MB
> Is this wrong??
> (A)                                                    (B)
> gdalbuildvrt -o /data/coastal-2020.vrt /vsis3/summer/1/coastal-2020.tif /
> The output in /data/coastal-2020.tif should be 6GB
> gdal_translate /data/coastal-2020.vrt /data/coastal-2020.tif -co
> BIGTIFF=YES -co COMPRESS=LZW -  -co NUM_THREADS=ALL_CPUS --config
> CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES  --config GDAL_SWATH_SIZE
> 1000000
> ##--config AWS_ACCESS_KEY_ID            set in ./config
> ##--config AWS_SECRET_ACCESS_KEY set in ./config
>  Regards,
> Clive Swan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221212/4371982f/attachment.htm>
