[gdal-dev] gdal-utils: About GDAL Python Utilities
Idan Miara idan at miara.com
Tue Feb 1 11:30:12 PST 2022
Hi Matt,
Thanks for looking into this.
Yes, you got it right.
You can find some documentation in the following pages, though it
certainly could be approved as per your suggestions, maybe also by using
some text from the RFC.
https://gdal.org/api/index.html#python-api
https://gdal.org/programs/index.html#programs (note the programs that end
with .py)
https://gdal.org/api/python_samples.html
These doc pages are auto generated from the sources here:
https://github.com/OSGeo/gdal/tree/master/doc/source
> Osgeo_utils doesn’t have a top level document yet.
I'm not sure what you mean by a top level document (it doesn't have its own
separate repository if that is what you meant).
>  It’s code root is .../swig/python/gdal-utils/osgeo_utils
<https://github.com/OSGeo/gdal/tree/master/swig/python/gdal-utils/osgeo_utils>
It is nested inside the gdal-utils project. In your IDE set gdal-utils as
the root folder. (*not sure about this. Is it better to have osgeo_utils as
root?)*
In order to make python use the package without installing it you need to
add its parent folder (that is  .../swig/python/gdal-utils/
as a source dir), which practically inserts that folder at the top of your
`sys.path`, which is where python looks for packages when you import. So
because your `site-packages` folder is in your `sys.path` by default, then
any package under it is recognized.
When you insert any other folder before it then it gets a higher priority
(and that is what happens when you mark as source dir).
> Contribute changes with Pull Requests
<https://github.com/OSGeo/gdal/pulls> from your fork to the main GDAL
project *(and use gdal-utils label?)*
Right, A dedicated label sounds like a good idea.
Please feel free to make a PR to improve the above docs by editing the RST
pages (https://github.com/OSGeo/gdal/tree/master/doc/source).
Feel free to ask further questions.
Idan.
On Tue, 1 Feb 2022 at 20:51, <Matt.Wilkie at yukon.ca> wrote:
> Hi,
> I had to read through *RFC 78: gdal-utils package
> <https://gdal.org/development/rfc/rfc78_gdal_utils_package.html>* a few
> times to wrap my head around what the major components are. Here’s some
> writing of what I think I understand. Is it correct?
> The GDAL python utilities are included with GDAL. If you’ve installed GDAL
> you already have them. However you may want to use a newer or older version
> of the utilities without changing GDAL. This is where *gdal-utils* comes
> in.
> *gdal-utils*: is the Gdal Python Utilities *distribution*. This is what
> you install. It’s home page is https://pypi.org/project/gdal-utils/ .
> Install it with `pip install gdal-utils` and it will up or downgrade the
> utilities in place.
> *osgeo_utils*: is the python *package*. This is what you use in your code
> after installing, e.g. `from osgeo_utils import ...`. If you’re not writing
> code, ignore it.
> *(something here, perhaps names links to the utilities that are available
> on command line)*
> Developers
> Clone or download the gdal project: https://github.com/OSGeo/gdal/
> Osgeo_utils doesn’t have a top level document yet. It’s code root is
> . It is nested inside the gdal-utils project. In your IDE set gdal-utils as
> the root folder.
> (*not sure about this. Is better to have osgeo_utils as root?)*
> Discuss via gdal-dev mailing list
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>.
> <https://github.com/OSGeo/gdal/pulls> from your fork to main GDAL project *(and
> Perhaps this could serve as part of a ‘gdal-utils’ project intro page
> somewhere. I think I still have write permissions to the Trac Wiki, but is
> that doesn’t feel like the right place to me.
> (BW, the Nabble archive links are broken on the RFC page.)
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | *Yukon.ca <http://yukon.ca/>*
> *Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.*
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220201/91df770b/attachment-0001.html>
