[gdal-dev] GDAL/OGR 3.4.1 not reading S57 correctly
Momtchil Momtchev momtchil at momtchev.com
Wed Feb 2 04:07:37 PST 2022
     I get exactly the same layers in /ogrinfo/ as I do with your
program both with GDAL 3.3.2 and GDAL 3.4.1 on all of your S57 files.
/s57/1B5X02NE.000/ has 13 layers.
     Here is the program I used: https://pastebin.com/z99xeQ92
On 28/01/2022 01:55, dthorne at pivotmaritime.com wrote:
> The S57 file we used to test with each language and it is read
> correctly in C# & python, our c++ project is the problem. The S57 is
> the one generated in "\gdal-3.4.1\autotest\ogr\data\s57" when we built
> gdal. But here is a link
> <https://drive.google.com/file/d/1AGCHEQMWHvs6IJgDW45KJvK6gm-r_cpH/view?usp=sharing>
> to that s57 folder.
> The specific s57 file we used was "1B5X02NE.000" which in reference to
> the first image I linked should have 13 layers.
> Thanks in advance for the help!
> Daniel
> -----Original Message-----
> From: "kusala nine" <kusala9 at googlemail.com>
> Sent: Friday, January 28, 2022 7:04am
> To: "Momtchil Momtchev" <momtchil at momtchev.com>
> Cc: dthorne at pivotmaritime.com, gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL/OGR 3.4.1 not reading S57 correctly
> I’m an S57 expert. Send me the data - I’ll take a look, there’s a lot
> of leeway with S57 and sometimes it trips up GDAL. I had issues with
> AML data before which is similar…
> Jonathan.
> Sent from my iPhone
>     On 27 Jan 2022, at 10:44, Momtchil Momtchev
>     <momtchil at momtchev.com> wrote:
>         Your code looks OK, can you send me the file too?
>     On 27/01/2022 03:34, dthorne at pivotmaritime.com wrote:
>         Here is the C++ code we have written to read the test s57 file.
>         https://pastebin.com/seXrkgmB
>         We feel that it is some setup stuff we have missed but can't
>         find any clear information. For example we hadn't seen
>         GDAL_DATA environment variables mentioned in any of the
>         documentation we've tried following until Even mentioned it.
>         Are there any other setup stuff we need to do?
>         <https://pastebin.com/seXrkgmB>
>         From: "Momtchil Momtchev" <momtchil at momtchev.com>
>         Sent: Wednesday, January 26, 2022 9:21pm
>         To: dthorne at pivotmaritime.com, gdal-dev at lists.osgeo.org
>         Can you post your C++ code? Generally, you have more chances
>         of getting an answer for this type of question on
>         https://gis.stackexchange.com/
>         On 24/01/2022 06:36, dthorne at pivotmaritime.com wrote:
>             Hi,
>             So I am trying to get a test C++ project built to read S57
>             files using the gdal/ogr C++ library.
>             I have previously used the C# library that is on there
>             NuGet manager which states v2.4.4 and that seems to read
>             the s57 without issues. Also tried python and that seems
>             to read it with no issues.
>             However, I am having a problem with the C++ test project.
>             Having built the C++ library into the .lib and .dll files
>             I have included them into a blank project and implemented
>             the functions to read the s57 file, however it is only
>             reporting 5 layers.
>             These 5 layers are the same no matter the s57 file. And 4
>             out of those 5 layers are not actually layers.
>             Using the autotest generated s57 file as a unit test to
>             cross check, there is supposed to be 13 layers.
>             Note: I had feedback from Even indicating the setup
>             environment is probably wrong. And to set up the GDAL_DATA
>             environment variable, so we've made an environment
>             variable referencing the gdal/data folder and that hasn't
>             fixed the problem, but I think it's on the right track as
>             Even said they could reproduce the problem if not setup
>             correctly.
>             *Has anyone had success reading s57 files with a C++
>             3.4.1. project that could possibly help get this going?*
>             Link to reference Image: https://imgur.com/a/KwmqZSe
>             Regards,
>             Daniel
>             _______________________________________________ gdal-dev
>             mailing list gdal-dev at lists.osgeo.org
>             https://lists.osgeo.org/mailman/listinfo/gdal-dev
>         -- Momtchil Momtchev <momtchil at momtchev.com>
>     gdal-dev mailing list
Momtchil Momtchev<momtchil at momtchev.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220202/1ea70632/attachment-0001.html>
