[gdal-dev] Access violation OGRSpatialReference.importFromESRI() in GDAL304.dll
Paul Meems bontepaarden at gmail.com
Fri Feb 4 08:34:58 PST 2022
Thanks Even,
That solved the problem.
I've read the manual several times today but overlooked that the parameter
should be a list.
Our code hasn't changed for years so this bug was unnoticed for a very long
time ;)
Regards,
Paul
Op vr 4 feb. 2022 om 16:56 schreef Even Rouault <even.rouault at spatialys.com
> RTF(antastic)M :-)
> https://gdal.org/doxygen/classOGRSpatialReference.html#af91af2639702e2793daf93ffe231b577
> Parameters
> papszPrj NULL terminated list of strings containing the definition.
> So change your code to something like:
>   char apszPrj[2];
>   char* s = proj.GetBuffer();
>   apszPrj[0] = s;
>   apszPrj[1] = NULL;
>   return sr->importFromWkt(apszPrj);
> Le 04/02/2022 à 16:47, Paul Meems a écrit :
> Hi List,
> We use GDAL v3+ in our Open Source mapping application MapWinGIS.
> We build using VS2019 on Windows and we use the files from GisInternals.
> We have a GeoProjection class which in turn calls
> some/most OGRSpatialReference methods.
> When calling OGRSpatialReference.importFromESRI() compiled for Win32 we
> have no issues.
> When calling the same code compiled for Win64 we get this exception:
> Exception thrown at 0x00007FFD93074839 (gdal304.dll) 0xC0000005: Access
> violation reading location 0xFFFFFFFFFFFFFFFF
> We also implement the very similar method importFromWkt(). This method has
> no issues on Win32 or Win64.
> Here's some relevant code from GeoProjection.cpp:
> STDMETHODIMP CGeoProjection::ImportFromESRI(const BSTR proj, VARIANT_BOOL*
> retVal)
>   AFX_MANAGE_STATE(AfxGetStaticModuleState())
>   USES_CONVERSION;
>   const CString s = OLE2A(proj);
>   const OGRErr err = ProjectionHelper::ImportFromEsri(_projection, s);
>   *retVal = err == OGRERR_NONE ? VARIANT_TRUE : VARIANT_FALSE;
>   if (err != OGRERR_NONE)
>     ReportOgrError(err);
>   return S_OK;
> STDMETHODIMP CGeoProjection::ImportFromWKT(const BSTR proj, VARIANT_BOOL*
> retVal)
>   USES_CONVERSION;
>   const OGRErr err = ProjectionHelper::ImportFromWkt(_projection, s);
>   return S_OK;
> And from ProjectionHelper.cpp:
> OGRErr ProjectionHelper::ImportFromEsri(OGRSpatialReference* sr, CString
> proj)
>   if (!sr) {
>     return false;
>   return sr->importFromESRI(&s);
> OGRErr ProjectionHelper::ImportFromWkt(OGRSpatialReference* sr, CString
> proj)
>   if (!sr) {
>     return false;
>   return sr->importFromWkt(&s);
> We're currently upgrading from GDAL2+ to GDAL3+.
> Users report the crash in both versions.
> Most likely we're not calling the importFromESRI correctly.
> Please advice.
> Regards,
> Paul Meems
> https://github.com/MapWindow/MapWinGIS
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220204/11ae6250/attachment-0001.html>
