[gdal-dev] GDAL, Proj and cacert
Paul Harwood runette at gmail.com
Fri Feb 11 09:24:02 PST 2022
I have an application that uses GDAL with Proj Networking set on.
This is a cross platform application. It works on some platforms but on mac
(for instance) I get runtime errors like this
GDAL failure (1) PROJ: Cannot open https://cdn.proj.org/us_nga_egm96_15.tif:
error setting certificate file: xxx/cacert.pem
Proj is looking in the wrong place for the cacert file - which is in the
proj search path. I would rather avoid using environment
variables (complicated). Is there a programmatic way to set the Proj cacert
location or a default location?
currently - the following are set
Gdal.SetConfigOption("CURL_CA_BUNDLE", Path.Combine(gdalData, "cacert.pem"
Osr.SetPROJSearchPath(projData);
Osr.SetPROJEnableNetwork(true);
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220211/c35b142d/attachment.html>
