[gdal-dev] GDAL, Proj and cacert
Paul Harwood runette at gmail.com
Fri Feb 11 09:40:23 PST 2022
Ok - thanks.
On Fri, 11 Feb 2022 at 17:38, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 11/02/2022 à 18:24, Paul Harwood a écrit :
> > I have an application that uses GDAL with Proj Networking set on.
> > This is a cross platform application. It works on some platforms but
> > on mac (for instance) I get runtime errors like this
> > GDAL failure (1) PROJ: Cannot open
> > https://cdn.proj.org/us_nga_egm96_15.tif: error setting certificate
> > file: xxx/cacert.pem
> > Proj is looking in the wrong place for the cacert file - which is in
> > the proj search path. I would rather avoid using environment
> > variables (complicated). Is there a programmatic way to set the Proj
> > cacert location or a default location?
> > currently - the following are set
> > Gdal.SetConfigOption("CURL_CA_BUNDLE", Path.Combine(gdalData,
> > "cacert.pem"));
> The logic in PROJ is:
>      // Custom path to SSL certificates.
>      if (ca_bundle_path == nullptr) {
>          ca_bundle_path = getenv("PROJ_CURL_CA_BUNDLE");
>          // Name of environment variable used by the curl binary
>          ca_bundle_path = getenv("CURL_CA_BUNDLE");
>          // Name of environment variable used by the curl binary (tested
>          // after CURL_CA_BUNDLE
>          ca_bundle_path = getenv("SSL_CERT_FILE");
>      if (ca_bundle_path != nullptr) {
>          CHECK_RET(ctx,
>                    curl_easy_setopt(handle, CURLOPT_CAINFO,
> ca_bundle_path));
> There's no programmatic way, at least currently. You need to set a real
> environment variable . CPLSetConfigOption() has no effect on PROJ, only
> on GDAL
> > Osr.SetPROJSearchPath(projData);
> > Osr.SetPROJEnableNetwork(true);
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220211/9e72f3b2/attachment.html>
