[gdal-dev] gdal-utils: Testing?
Even Rouault even.rouault at spatialys.com
Sat Feb 12 02:08:20 PST 2022
Le 12/02/2022 à 05:25, Matt Wilkie a écrit :
> Hi,
> Is there a way to run autotests/pytest only for gdal-utils,
you meant autotest/pyscripts, right ?
> or only those tests that involve a certain folder tree?
good question. The logic to locate the .py scripts is in get_py_script()
function of autotest/pymod/test_py_scripts.py and is likely dependent on
the OSGeo/gdal tree structure
> -matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
