[gdal-dev] GDAL, Proj and cacert
Even Rouault even.rouault at spatialys.com
Sat Feb 12 10:34:19 PST 2022
> - What would be nice would be an explicit way of setting the default
> for PROJ. Since version 7 - PROJ has an ini file but it does not seem
> to include the cacert file. I can see why that might be seen as being
> a potential security hole - although I would point out that the ini
> file DOES allow specification of the CDN URL. From a security point of
> view - those two facts together kind of say "you can do a man in the
> middle attack if and only if your attack is inherently insecure" ... :)
(Most of the time things are the way they are because nobody had the
need to implement the missing feature or took time to do it. People able
to control environment variables or the content of a local file are
equivalent "threats")
https://github.com/OSGeo/PROJ/pull/3049 should help hopefully
Even
http://www.spatialys.com
