[gdal-dev] Corrupted geopackage
    Rahkonen Jukka (MML)
    jukka.rahkonen at maanmittauslaitos.fi
    Mon Feb 14 00:26:19 PST 2022
Without being able to see your database it is hard to give more advice that https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 gives. Did you try all of them? Because the problem has something to do with the spatial index I would have a try be dropping it and repeating the suggested tricks.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Isabel Kiefer
Lähetetty: maanantai 14. helmikuuta 2022 10.17
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Corrupted geopackage
Hi everyone,
I've a problem with a corrupted geopackage.
It should contain a table with 694 entries, but only 78 are visible when opening the file with DB Browser for SQLite or QGIS. The table gpkg_ogr_contents says 694 though. When opening the .gpkg with a Notepad or similar, I can see that there are more than 78 entries.
The error message in DB Browser is "database disk image is malformed in "PRAGMA "main".TABLE_INFO("rtree_XXX");" So it seems that there is a problem with the index of the concerned table.
Does anyone know how to fix this? I tried  https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 but without success.
Thanks in advance for your help!
Isabel
Isabel Kiefer
OPENGIS.ch
isabel at opengis.ch<mailto:isabel at opengis.ch>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/011bedef/attachment.html>
