[gdal-dev] Corrupted geopackage
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Feb 14 03:51:09 PST 2022
Maybe you can drop the rtree tables if you first drop the rtree_xxx triggers that belong to the data table. There are probably 6 of them. I don’t know if it helps, though. rtreecheck() https://sqlite.org/rtree.html is probably useless because you know already that the index is corrupted.
-Jukka-
Lähettäjä: Isabel Kiefer <isabel at opengis.ch>
Lähetetty: maanantai 14. helmikuuta 2022 13.08
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Corrupted geopackage
Hi Jukka,
Yes, exactly, there are only 78 entries in a dump to text file.
In the original .gpkg-file, the rtree_XX_geom table is completely empty (no columns, no entries) - this must be where the problem comes from..
On Mon, Feb 14, 2022 at 11:59 AM Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
And when you .dump https://www.sqlitetutorial.net/sqlite-dump/ the damaged table into a text file, do you only get 78 insert entries into it?
-Jukka-
Lähettäjä: Isabel Kiefer <isabel at opengis.ch<mailto:isabel at opengis.ch>>
Lähetetty: maanantai 14. helmikuuta 2022 12.53
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Kopio: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Thanks for your suggestion, Jukka! I tried all the advice from stackoverflow. I can do ".recover", but get only the features that have been visible all along.
In the original .gpkg, I cannot DROP the affected RTree-Index. It gives me the same disk malformed error. But that would also have been my initial idea...
On Mon, Feb 14, 2022 at 9:26 AM Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Without being able to see your database it is hard to give more advice that https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 gives. Did you try all of them? Because the problem has something to do with the spatial index I would have a try be dropping it and repeating the suggested tricks.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Isabel Kiefer
Lähetetty: maanantai 14. helmikuuta 2022 10.17
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Corrupted geopackage
Hi everyone,
I've a problem with a corrupted geopackage.
It should contain a table with 694 entries, but only 78 are visible when opening the file with DB Browser for SQLite or QGIS. The table gpkg_ogr_contents says 694 though. When opening the .gpkg with a Notepad or similar, I can see that there are more than 78 entries.
The error message in DB Browser is "database disk image is malformed in "PRAGMA "main".TABLE_INFO("rtree_XXX");" So it seems that there is a problem with the index of the concerned table.
Does anyone know how to fix this? I tried  https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 but without success.
Thanks in advance for your help!
Isabel
Isabel Kiefer
OPENGIS.ch
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/d5ae3aca/attachment-0001.html>
