[gdal-dev] Corrupted geopackage
Isabel Kiefer isabel at opengis.ch
Mon Feb 14 04:52:36 PST 2022
Thanks a lot for your help Jukka and Even. While I can drop the related
triggers, I cannot drop the index table and its shadow tables - it always
gives the database disk image malformed message.
ogr2ogr had worked - as you said - for the visible data. I guess the other
data is lost for good...
On Mon, Feb 14, 2022 at 1:25 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> I would just suggest using ogr2ogr to generate a new 'clean' GPKG file
> from the corrupted one. This will not recover lost data, but at least
> you'll get something sane. Well I should say "structurally" sane. depending
> on how the corruption happened you could get also get corrupted content in
> the data that tools can't detect (there's no checksum mechanism at the row
> level in sqlite)
> Le 14/02/2022 à 12:51, Rahkonen Jukka (MML) a écrit :
> Hi,
> Maybe you can drop the rtree tables if you first drop the rtree_xxx
> triggers that belong to the data table. There are probably 6 of them. I
> don’t know if it helps, though. rtreecheck() https://sqlite.org/rtree.html
> is probably useless because you know already that the index is corrupted.
> -Jukka-
> *Lähettäjä:* Isabel Kiefer <isabel at opengis.ch> <isabel at opengis.ch>
> *Lähetetty:* maanantai 14. helmikuuta 2022 13.08
> *Vastaanottaja:* Rahkonen Jukka (MML)
> <jukka.rahkonen at maanmittauslaitos.fi>
> <jukka.rahkonen at maanmittauslaitos.fi>; gdal-dev at lists.osgeo.org
> *Aihe:* Re: [gdal-dev] Corrupted geopackage
> Hi Jukka,
> Yes, exactly, there are only 78 entries in a dump to text file.
> In the original .gpkg-file, the rtree_XX_geom table is completely empty
> (no columns, no entries) - this must be where the problem comes from..
> On Mon, Feb 14, 2022 at 11:59 AM Rahkonen Jukka (MML) <
> jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> And when you .dump https://www.sqlitetutorial.net/sqlite-dump/ the
> damaged table into a text file, do you only get 78 insert entries into it?
> -Jukka-
> *Lähetetty:* maanantai 14. helmikuuta 2022 12.53
> *Vastaanottaja:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> *Kopio:* gdal-dev at lists.osgeo.org
> Thanks for your suggestion, Jukka! I tried all the advice from
> stackoverflow. I can do ".recover", but get only the features that have
> been visible all along.
> In the original .gpkg, I cannot DROP the affected RTree-Index. It gives me
> the same disk malformed error. But that would also have been my initial
> idea...
> On Mon, Feb 14, 2022 at 9:26 AM Rahkonen Jukka (MML) <
> Hi,
> Without being able to see your database it is hard to give more advice
> that
> https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642
> gives. Did you try all of them? Because the problem has something to do
> with the spatial index I would have a try be dropping it and repeating the
> suggested tricks.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Isabel
> Kiefer
> *Lähetetty:* maanantai 14. helmikuuta 2022 10.17
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] Corrupted geopackage
> Hi everyone,
> I've a problem with a corrupted geopackage.
> It should contain a table with 694 entries, but only 78 are visible when
> opening the file with DB Browser for SQLite or QGIS. The table
> gpkg_ogr_contents says 694 though. When opening the .gpkg with a Notepad or
> similar, I can see that there are more than 78 entries.
> The error message in DB Browser is "database disk image is malformed in
> "PRAGMA "main".TABLE_INFO("rtree_XXX");" So it seems that there is a
> problem with the index of the concerned table.
> Does anyone know how to fix this? I tried
> https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642 but
> without success.
> Thanks in advance for your help!
> Isabel
> Isabel Kiefer
> OPENGIS.ch
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/e67e29fd/attachment-0001.html>
