[gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Feb 14 11:26:45 PST 2022
Does http://mydomain:3000/rpc/wod_geojson.json return data if you send it with browser?  Re-run the ogrinfo command with “--debug on” and see if you can capture the http requests that ogrinfo sends.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta SIGéal
Lähetetty: maanantai 14. helmikuuta 2022 20.54
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
Hi list,
I have a PostgreSql stored procedure which returns a geojson feature collection created with json_build_object function. This web service opens fine in OpenLayers, however, when I try to open it in QGIS, with data source manager -> vector -> protocol -> geojson.
A similar REST service served with pg_featureserv, works well...
Here are tests realised with curl and ogrinfo for failing postgrest service and working pg_featureserv services :
PostGrest
curl answer :
StatusCode        : 200
StatusDescription : OK
Content           : {123, 34, 116, 121...}
RawContent        : HTTP/1.1 200 OK
                    Transfer-Encoding: chunked
                    Content-Range: 0-0/*
                    Vary: Accept-Encoding
                    Content-Type: application/geo+json
                    Date: Sun, 13 Feb 2022 07:35:55 GMT
                    Server: postgrest/9.0.0
                    {"type" : ...
Headers           : {[Transfer-Encoding, chunked], [Content-Range, 0-0/*], [Vary, Accept-Encoding], [Content-Type,
                    application/geo+json]...}
RawContentLength  : 430979
ogrinfo answer :
ERROR 1: HTTP error code : 404
FAILURE:
Unable to open datasource `http://mydomain:3000/rpc/wod_geojson.json' with the following drivers...
pg_featureserv
curl answer :
StatusCode        : 200
                    Date: Sun, 13 Feb 2022 07:33:51 GMT
                    {"type":"FeatureCollection","features":[{"type":"Feature","geometry":{"type":"Po...
Headers           : {[Transfer-Encoding, chunked], [Content-Type, application/geo+json], [Date, Sun, 13 Feb 2022
                    07:33:51 GMT]}
RawContentLength  : 4474
ogrinfo answer :
INFO: Open of `http://mydomain:9000/functions/webmapod_mdarret/items.json'
      using driver `GeoJSON' successful.
1: items (Point)
What could explain that 404 error for posgrest geojson web service ?
Thanks for any hint,
Christophe Damour
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220214/8e9d3083/attachment.html>
