[gdal-dev] Strange (expected?) behaviour exporting multipart geometry to ESRI Shapefile format
Andrea Giudiceandrea andreaerdna at libero.it
Wed Feb 16 04:24:21 PST 2022
Il 16/02/2022 12:24, Even Rouault ha scritto:
> your [2] link contains the shapefile, not the GeoPackage file.
Hi Even,
yes, you are right. The correct URL for the GeoPackage layer is
https://drive.google.com/file/d/1DMMbFQ922d_ccS00JIt0KaojGk6jMorb
> Or you can use the SHAPE_REWIND_ON_WRITE configuration option
> mentioned at
> https://gdal.org/drivers/vector/shapefile.html#advanced-topics :
> ogr2ogr out3.shp Issue47288_Polygons.gpkg --config
> SHAPE_REWIND_ON_WRITE OFF
> This will keep the original geometry mostly untouched, possibly
> creating a non-conformant shapefile. And on the reading side, the OGR
> shapefile reader might also have issues reconstructing a
> single-feature geometry. On that particular case, it seems to produce
> the "expected" result
Yes, exporting to Shapefile with this option, the visualization issue in
QGIS doesn't occur in this case and the parts maintain their
winding/orientation.
Thanks for the insight about the issue and on how the driver works under
the hood and deal with the (not always clear) specification.
> My inclination would be to consider that in the case where we have a
> multipolygon with non -coplanar parts we should probably be avoiding
> considering the ones that are non-coplanar are inner/outer rings of
> others.
> I've ticketed that in https://github.com/OSGeo/gdal/issues/5315
Thank you again.
Best regards.
Andrea
