[gdal-dev] Corrupted geopackage
Jonathan Moules jonathan-lists at lightpear.com
Wed Feb 16 11:56:51 PST 2022
Hi Isabel,
If you don't get an answer here, you may want to try the SQLite forum:
https://sqlite.org/forum/forum - If anyone knows, it'll be someone there.
Maybe also of interest: https://sqlite.org/howtocorrupt.html#cfgerr
Cheers,
Jonathan
On 2022-02-14 08:17, Isabel Kiefer wrote:
> Hi everyone,
> I've a problem with a corrupted geopackage.
> It should contain a table with 694 entries, but only 78 are visible
> when opening the file with DB Browser for SQLite or QGIS. The table
> gpkg_ogr_contents says 694 though. When opening the .gpkg with a
> Notepad or similar, I can see that there are more than 78 entries.
> The error message in DB Browser is "database disk image is malformed
> in "PRAGMA "main".TABLE_INFO("rtree_XXX");" So it seems that there is
> a problem with the index of the concerned table.
> Does anyone know how to fix this? I tried
> https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642
> <https://stackoverflow.com/questions/18259692/how-to-recover-a-corrupt-sqlite3-database/18260642> but
> without success.
> Thanks in advance for your help!
> Isabel
> Isabel Kiefer
> OPENGIS.ch
> isabel at opengis.ch
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220216/0f61d3d7/attachment.html>
