[gdal-dev] Adding OSGEO4W and gisinternals docs in install doc?
Even Rouault even.rouault at spatialys.com
Thu Feb 17 10:44:34 PST 2022
Le 17/02/2022 à 19:22, Tamas Szekeres a écrit :
> To be correct, the latest version of the build scripts (including the
> Makefile) are on the refactor branch:
> https://github.com/gisinternals/buildsystem/tree/refactor
nice! I actually see
https://github.com/gisinternals/buildsystem/blob/refactor/config.opt
with the URLs of the upstream repositories, and the build commands in
https://github.com/gisinternals/buildsystem/blob/refactor/Makefile
Is the refactor branch the one used for the builds at gisinternals.com ?
(said otherwise, why isn't it the master branch ?)
> Tamas Szekeres <szekerest at gmail.com> ezt írta (időpont: 2022. febr.
> 17., Cs, 19:19):
>     For gisinternals, the entire build including the dependencies is
>     controlled by a single Makefile
>     <https://github.com/gisinternals/buildsystem/blob/master/Makefile>
>     which controls the builds of the dependencies including how to
>     obtain them from the source repositories. The makefile also
>     contains the necessary tweaks that had to be applied in a
>     dependency if that required for a successful build.
>     Best regards,
>     Tamas
>     Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2022.
>     febr. 17., Cs, 17:29):
>         Thomas,
>         One criterion currently for inclusion is: "In this section we
>         list a
>         number of the binary distributions of GDAL all of which should
>         have
>         fully reproducible open source build recipes."
>         I've not evaluated what the current situation of OSGeo4W or
>         gisinternals
>         is regarding this, especially regarding all direct and indirect
>         dependencies of GDAL (or course, that must stop at the
>         compiler level
>         when using Visual Studio). I believe nowadays OSGeo4W must be
>         closer to
>         that aim of having fully reproducible builds, but I'm not sure
>         to which
>         extent. For gisinternals I'm not sure. It was my impression
>         that the
>         build recipees for the dependencies were not available, but
>         maybe I'm
>         wrong. I'll let the developers of those distributions comment
>         further if
>         they wish.
>         Even
>         Le 17/02/2022 à 17:17, Thomas Gratier a écrit :
>         > Hi,
>         > I regularly orient third parties to use GDAL utilities and
>         for this
>         > intent, point them to install section
>         > https://gdal.org/download.html#binaries
>         > For Windows, I did not see a user friendly section about how to
>         > install it. I want to mention in the doc how to install with
>         OSGEO4W
>         > and https://www.gisinternals.com/index.html
>         > Opinions? If ok, I will do a PR later on the github repo
>         > Regards
>         > Thomas Gratier
>         > _______________________________________________
>         > gdal-dev mailing list
>         > gdal-dev at lists.osgeo.org
>         > https://lists.osgeo.org/mailman/listinfo/gdal-dev
>         http://www.spatialys.com
>         My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220217/da13bad3/attachment.html>
