[gdal-dev] Gdal_translate into HDF4 fails
Even Rouault even.rouault at spatialys.com
Fri Feb 18 06:39:41 PST 2022
if you gdal_translate -of netCDF -co FORMAT=NC4 , the resulting netCDF
file will actually be a HDF5 file (with netCDF "decorations"):
- https://gdal.org/drivers/raster/netcdf.html#creation-options
https://www.unidata.ucar.edu/software/netcdf/docs/interoperability_hdf5.html
Le 18/02/2022 à 15:24, Lorenzo Di Giacomo a écrit :
> Hi guys, i was reading the question and i was wondering if it's
> possibile do the same translate operation with HDF5, like:
> gdal_translate -of HDF5Image 3band.tif out.h5, i tried but doesn't
> work and says "
> HDF5 driver has no creation capabilities."
> Thanks
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220218/247453e2/attachment.html>
