[gdal-dev] using the docker images: updating?
Even Rouault even.rouault at spatialys.com
Tue Feb 22 06:41:29 PST 2022
You're root by default inside the container when using docker with
standard invokation, so no need of sudo
Le 22/02/2022 à 15:31, Matt Wilkie a écrit :
> When using the docker images, particularly 'osogeo/gdal' from docker
> hub, sudo isn't available. How does one `apt update` etc?
> thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
