[gdal-dev] Use GitPod for GDAL?
Matt Wilkie maphew at gmail.com
Tue Feb 22 08:24:45 PST 2022
I finally have a working recipe for getting Gitpod fired up with a
pre-populated gdal docker image!
At Github repo root create .gitpod.yml:
image:
  file: .gitpod.Dockerfile
And in .gitppod.Dockerfile:
FROM osgeo/gdal:ubuntu-small-latest
RUN uname -a && cat /etc/os-release
RUN apt-get update --fix-missing
RUN apt-get install -y sudo libproj-dev
And then launch https://gitpod.io/#https://github.com/PATH/TO/REPO
Working example:
https://gitpod.io/#https://github.com/maphew/gdal/tree/gitpod
There's still some things to sort out, like sudo doesn't work because it
asks for a password, but gdalinfo and friends are all there and happy.
-matt
On Fri, Feb 18, 2022 at 3:38 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Matt,
> you need to install the "libproj-dev" package.
> Looking at the CI build recipees is a source of good hints in general:
> https://github.com/OSGeo/gdal/blob/6e6aff451dbcde450f051bff2f2e75ce6a4a3e6f/.github/workflows/cmake_builds.yml#L38
> (this one has pretty much all the pre packaged dependencies. you don't need
> all that)
> Even
> Le 18/02/2022 à 23:34, Matt Wilkie a écrit :
> This what I've come up with:
> https://gitpod.io
> Create new >> search for gdal >> select OSGeo/gdal
> On launch:
> -- Could NOT find PROJ (missing: PROJ_DIR)
> CMake Error at
> /home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230
> (message):
>   Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR) (Required
> is
>   at least version "6.0")
> Call Stack (most recent call first):
>   /home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594
> (_FPHSA_FAILURE_MESSAGE)
>   cmake/modules/packages/FindPROJ.cmake:57
> (find_package_handle_standard_args)
>   cmake/helpers/CheckDependentLibraries.cmake:303 (find_package)
>   gdal.cmake:210 (include)
>   CMakeLists.txt:206 (include)
> Attempted to remedy this with `sudo apt install proj-bin` but same error
> from `cmake .`
> The below adapted from
> https://github.com/maphew/gdal/blob/pr-5281-redux/CONTRIBUTING.md
> cd /workspace/gdal
> ./autogen.sh
> ./configure --with-python
> Fails with "configure: error: PROJ 6 symbols not found".
> tried `sudo apt install proj-bin` and repeated above, same error.
> Version of proj that's installed with this is 6.3.1.
> Try building Proj from source (takes awhile):
> cd /workspace
> wget https://download.osgeo.org/proj/proj-6.3.1.tar.gz
> tar zxf proj-*.gz
> cd proj-6.3.1
> ./configure
> make && sudo make install
> Now try again (takes much longer):
> cd /workspace/gdal
> ./autogen.sh
> make -j8
> sudo make install
> It works!
> . scripts/setdevenv.sh
> gdalinfo --version
> GDAL 3.5.0dev-39057d7396, released 2022/02/18
> uname -a
> inux osgeo-gdal-j6a7bhjf0c8 5.13.0-1013-gcp #16-Ubuntu SMP Tue Jan 18
> 14:31:35 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
> I'm still unable to successfully install a python wheel of gdal-utils,
> because pip is calling g++ which in turn is not finding libgdal, but it
> still feels like significant progress to get this far! :)
> -matt
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220222/ce133cb0/attachment-0001.html>
