[gdal-dev] HDF4Image stuck on translate
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue Feb 22 08:47:03 PST 2022
It was sluggish last week and still is, I guess that especially with multi-band images https://lists.osgeo.org/pipermail/gdal-dev/2022-February/055474.html. Run the command with “ -- debug on” and you have more to follow when you see how Flushing dirty blocks is slowly progressing.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Lorenzo Di Giacomo
Lähetetty: tiistai 22. helmikuuta 2022 18.10
Vastaanottaja: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] HDF4Image stuck on translate
Hi, i'm doing some "conversion" test, from one format to another (mainly from TIFF to ALL).
I found in HDF4Image driver that on some images, it get stuck.
gdal_translate -of HDF4Image source.tiff dest.hdf
Input file size is 2861, 3635
0...10...20...30...40...50...60...70...80...90...100 - done.
And remain in this state. For image as big as this above, i let it for about 1 hour and still blocked.
Is it normal that required all this time ? Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220222/a3431a5b/attachment.html>
