[gdal-dev] [External] : Re: how to build netCDF driver plugin
Fengting Chen fengting.chen at oracle.com
Fri Feb 25 11:28:41 PST 2022
I downloaded the process monitor and it helped. It turns out that the netcdf.dll couldn’t be found due to the space in the path.
Thanks a lot for the help.
-Fengting
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Mateusz Loskot
Sent: Friday, February 25, 2022 2:39 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] [External] : Re: how to build netCDF driver plugin
On Fri, 25 Feb 2022, 07:01 Fengting Chen, <fengting.chen at oracle.com<mailto:fengting.chen at oracle.com>> wrote:
After fix the plugin library name, the netCDF driver plugin on linux is working. However, it still didn’t work on windows:
E:\tmp\gdal>gdalinfo
ERROR 1: Can't load requested DLL: E:\tmp\gdal\bin\gdalplugins\gdal_netCDF.dll
126: The specified module could not be found.
I verified that specified gdal_netCDF.dll exists at above directory and netcdf.dll is in the path of %PATH%.
Any possible problem?
Lots.
Use the process monitor (sysinternals, downloadable from Microsoft website) to investigate what DLLs are being loaded and from where, and which fail to be found.
Mateusz Loskot, http://mateusz.loskot.net<https://urldefense.com/v3/__http:/mateusz.loskot.net__;!!ACWV5N9M2RV99hQ!ZCIAz-yN6aVvZ1OAjila7z6ZB1cy2LKni1jhjEOr8Y_Q4ZMtQokvtSt9iJuOHWErbX4$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220225/6f0e4be0/attachment-0001.html>
