[gdal-dev] Fwd: DOI for the GDAL project / Springer Handbook of Geoinformatics
Even Rouault even.rouault at spatialys.com
Thu Jan 20 07:49:49 PST 2022
Ok, I went ahead with a manual upload of GDAL 3.4.1:
https://zenodo.org/record/5884352 , with concept DOI being
https://zenodo.org/record/5884351
Can you ask the zenodo help desk to link the later with the github
releases of https://github.com/OSGeo/GDAL ?
Same for PROJ 8.2.1: https://zenodo.org/record/5884395, with concept DOI
being https://zenodo.org/record/5884394, to be associated with
https://github.com/OSGeo/PROJ
Even
Le 20/01/2022 à 15:37, Peter Löwe a écrit :
> Hi,
> FYI here's the confirmation by Zenodo about the combined use of manual and automated software versioning:
> "It is possible to link manual releases to the GitHub integration automated workflow.
> You can go ahead and publish the two manual releases and share them here.
> We will then link them to the equivalent GitHub repositories so that when you activate the integration new versions will continue under the same Concept DOIs of the manual releases"
> -> the two repos being referred to are PROJ and GDAL.
> I will not be ablé to act on this as I do not have admin access to neither the GDAL nor the PROJ repo.
> Best,
> Peter
> <peter.loewe at gmx.de>
>> Gesendet: Donnerstag, 20. Januar 2022 um 10:16 Uhr
>> Von: "Peter Löwe" <peter.loewe at gmx.de>
>> An: gdal-dev at lists.osgeo.org
>> Betreff: [gdal-dev] Fwd: DOI for the GDAL project / Springer Handbook of Geoinformatics
>> Hello gdal-dev-list,
>> regarding the current discussion on how to register DOI for GDAL, I've contacted the helpdesks of Zenodo and DataCite. DataCite is the organisation providing the global DOI-infrastructure. Zenodo is an open access repository where a growing number of OSGeo projects already have registered DOI for their codebases.
>> The question is whether once a DOI for GDAL has been registered manually/retrospectively for the current release (GDAL 3.4.1) it will be feasible to switch to automated DOI versioning for all future GDAL releases.
>> The DataCite helpdesk confirms, this approach from their infrastructure perspective: "From the DataCite side I don't see anything that would mean the manual workflow could not change to an automated one, but this is something that Zenodo would need to confirm."
>> The Zenodo helpdesk confirmed this approach last night: "We can actually connect this record to a "virtual" release on our side as if it was actually part of the Github repo. Could you give us more details, for example, the records in question and the GitHub repos?".
>> -> I have told them that this applies to GDAL (among other projects). No response yet.
>> Maybe someone of the project community is interested and able to contact the Zenodo help desk directly on this (info at zenodo.org) ?
>> The deadline to include a DOI for the GDAL project to the Open Source Chapter of the Springer Handbook on Geographic Information is today end of business Pacific Time.
>> By now, ten OSGeo projects will have their DOI referenced in the Chapter (more to come in the next hours). It would be awesome if GDAL could be included, too.
>> Best,
>> Peter
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
