[gdal-dev] cmake status update - 99% good news!
Even Rouault even.rouault at spatialys.com
Wed Jan 26 11:23:47 PST 2022
Le 26/01/2022 à 20:08, Joaquim Manuel Freire Luís a écrit :
> Updated master (sorry, didn’t stop to think if the commit had been merged)
> However, I have cmake 3.22.1 but it doesn’t have a FindHDF4.cmake,
> only a FinfHDF5
FindHDF4.cmake is in the GDAL repository, in
cmake/modules/packages/FindHDF4.cmake, so you can try editing it locally
with my below suggestions
> I was building with
>                set(HDF4_INCLUDE_DIR
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_34/include)
>                set(HDF4_df_LIBRARY_RELEASE
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/hdfdll.lib)
>            set(HDF4_mfhdf_LIBRARY_RELEASE
> C:/programs/compa_libs/hdf-4.2.9/compileds/VC14_64/lib/mfhdfdll.lib)
> and when I commented those lines the build advance … till it stop at
> the “Cannot open include file: 'zlib.h'” but that is normal since I’m
> not using the commit who fixed it.
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Wednesday, January 26, 2022 6:50 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] cmake status update - 99% good news!
> did you update to master or did you try my pull request (not merged yet) ?
> If only master, can you try to change the reference to "ws2_32.lib" to
> "ws2_32" in cmake/modules/packages/FindHDF4.cmake as I suggested ?
> Or perhaps change the if (WIN32) at line 91 to if (MSVC)
> Le 26/01/2022 à 19:43, Joaquim Manuel Freire Luís a écrit :
>     Don’t know which commit did it. Updated this afternoon and started
>     to erroring right away with missing 'ws2_32.lib`
>     <mailto:even.rouault at spatialys.com>
>     *Sent:* Wednesday, January 26, 2022 6:36 PM
>     <mailto:jluis at ualg.pt>; gdal-dev at lists.osgeo.org
>     Le 26/01/2022 à 19:31, Joaquim Manuel Freire Luís a écrit :
>         I do have HDF4 but before I was able to build till the end.
>         I've here a gdal_w64.dll smiling to me. That's why I said it
>         got worst.
>     Sorry you lost me. Is https://github.com/OSGeo/gdal/pull/5179
>     <https://github.com/OSGeo/gdal/pull/5179> helping or not ?  If not
>     helping, which commit in it is causing an issue ?
>         Le 26/01/2022 à 17:26, Joaquim Manuel Freire Luís a écrit :
>         > Joaquim,
>         >> But I found two other new issues when adding more dependencies
>         >> 1.
>         C:\programs\compa_libs\gdal_GIT\frmts\mbtiles\mbtilesdataset.cpp(45):
>         >> fatal error C1083: Cannot open include file: 'zlib.h': No
>         such file
>         >> or directory
>         >> To work around this, I temporarily added zlib.h and zconf.h to
>         >> frmts\mbtiles
>         > Should be fixed by the first commit of
>         > I'm afraid it got worst
>         -- Configuring done
>         -- Generating done
>         -- Build files have been written to:
>         C:/programs/compa_libs/gdal_GIT/build
>         ninja: error: 'ws2_32.lib', needed by 'gdal_w64.dll', missing
>         and no known rule to make it
>         I'd say on the contrary that it helped the build to go
>         further, didn't it ? My fixes are totally unrelated to a
>         ws2_32.lib missing
>         I see in configure.ac that we had the following logic
>         dnl
>         dnl Check if we need -lws2_32 (mingw)
>         dnl
>         echo "#include <winsock2.h>" > test_ws2_32.c echo "#include
>         <ws2tcpip.h>" >> test_ws2_32.c echo "void foo() {}" >>
>         test_ws2_32.c
>         if test -z "`${CC} -c test_ws2_32.c 2>&1`" ; then
>           LIBS="$LIBS -lws2_32"
>         fi
>         rm -f test_ws2_32*
>         dnl
>         dnl Check if we need -lpsapi (mingw)
>         dnl
>         echo "#include <windows.h>" > test_psapi.c echo "#include
>         <psapi.h>" >> test_psapi.c echo "void foo() {}" >> test_psapi.c
>         if test -z "`${CC} -c test_psapi.c 2>&1`" ; then
>           LIBS="$LIBS -lpsapi"
>         fi
>         rm -f test_psapi*
>         This hasn't been ported yet to cmake builds.
>         I've ticketed that in
>         https://github.com/OSGeo/gdal/issues/5180
>         <https://github.com/OSGeo/gdal/issues/5180>.
>         Hum, upon reflection, the error message would seem to indicate
>         that we try to link to ws2_32.lib but it is not found in your
>         environemnt
>         Looking for ws2_32 in cmake build scripts, I see it is
>         referenced in
>         cmake/modules/packages/FindODBC.cmake:
>         set(_odbc_required_libs_names
>         odbccp32;ws2_32)
>         cmake/modules/packages/FindHDF4.cmake: list(APPEND HDF4_LIBRARIES
>         ws2_32.lib)
>         Do you use any of ODBC or HDF4 in your build ? Could you try
>         to disable them and see if it makes a difference ?
>         Or maybe if you've HDF4, try to change the ws2_32.lib to
>         ws2_32 in cmake/modules/packages/FindHDF4.cmake ?
>         Even
>         http://www.spatialys.com <http://www.spatialys.com>
>         My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/88c2c61a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220126/88c2c61a/attachment-0001.png>
