[gdal-dev] PDF Driver projection support for Mercator_1SP Mercator_2SP
Gane R gane.prog at gmail.com
Wed Jul 6 07:22:34 PDT 2022
Does the PDF driver support these projections
Here is such an example of file with projection
https://lists.osgeo.org/pipermail/gdal-dev/2016-September/045147.html
I see some fix applied for GeoTIFF https://trac.osgeo.org/gdal/ticket/5791
Any thoughts? for PDF driver or I am wrong they already exists in latest
GDAL
Gane R
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220706/9f6b77c7/attachment.htm>
