[gdal-dev] cURL response content output
Even Rouault even.rouault at spatialys.com
Wed Jul 6 10:55:45 PDT 2022
Daniel,
https://github.com/OSGeo/gdal/pull/6028 should help, but with the
restriction indicated in the commit message.
Even
Le 06/07/2022 à 13:13, Daniel Evans a écrit :
> Hi,
> I'm trying to diagnose some issues with accessing remote datasets in
> GDAL - I believe the problem is unrelated to GDAL itself, but it's
> proving hard to debug.
> By enabling CPL_CURL_VERBOSE, I can see that the server is kicking
> back a 400 Bad Request status, but the debug output doesn't include
> the actual response content, which would allow me to understand the
> problem in more detail. Is there a way to get GDAL/cURL to output the
> response content for failed requests?
> By way of example, if I attempt to access a nonexistent file on S3
> with cURL directly, I get the 404 error code and the descriptive
> XML error message at the end:
> $ curl -v https://a-very-very-fake-s3-bucket.s3.amazonaws.com/example.tif
> < HTTP/1.1 404 Not Found
> < Content-Type: application/xml
> < Transfer-Encoding: chunked
> < Date: Wed, 06 Jul 2022 11:09:09 GMT
> < Server: AmazonS3
> --- these lines ---
> <?xml version="1.0" encoding="UTF-8"?>
> <Error><Code>NoSuchBucket</Code><Message>The specified bucket does not
> exist</Message><BucketName>a-very-very-fake-s3-bucket</BucketName>[...]</Error>
> --- these lines ---
> In contrast, the output from GDAL with CPL_CURL_VERBOSE excludes the
> XML response:
> < Date: Wed, 06 Jul 2022 11:04:16 GMT
> < Server: AmazonS3
> --- no XML output here ---
> * Connection #1 to host a-very-very-fake-s3-bucket.s3.amazonaws.com
> <http://a-very-very-fake-s3-bucket.s3.amazonaws.com> left intact
> * Couldn't find host a-very-very-fake-s3-bucket.s3.amazonaws.com
> <http://a-very-very-fake-s3-bucket.s3.amazonaws.com> in the .netrc
> file; using defaults
> * Found bundle for host a-very-very-fake-s3-bucket.s3.amazonaws.com
> <http://a-very-very-fake-s3-bucket.s3.amazonaws.com>: 0x25b5080 [can
> pipeline]
> * Re-using existing connection! (#1) with host
> * Connected to a-very-very-fake-s3-bucket.s3.amazonaws.com
> <http://a-very-very-fake-s3-bucket.s3.amazonaws.com> (52.216.207.115)
> port 443 (#1)
> > GET /?delimiter=%2F&max-keys=100&prefix=example.tif%2F HTTP/1.1
> Regards,
> Daniel
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220706/2189be8b/attachment.htm>
