[gdal-dev] New behaviour of "PROMOTE_TO_MULTI" ?
Richard Greenwood richard.greenwood at gmail.com
Mon Jul 25 06:32:35 PDT 2022
Have you tried -nlt MultiPolygon?
On Mon, Jul 25, 2022 at 2:54 AM Bo Victor Thomsen <
bo.victor.thomsen at gmail.com> wrote:
> I have a MapInfo .tab file containing polygons, both simple and
> multipolygons (and only polygons).
> Using this command: (all ogr2ogr commands are one-liners, but examples are
> split for lucidity)
> ogr2ogr
>   --config PG_USE_COPY yes
>   -progress
>   -lco OVERWRITE=YES
>   -dim XY
>   -f "PostgreSQL" PG:"host=localhost port=5432 user=*** password=***
> dbname=geodata"
>   FREDSKOV.TAB
> will (correctly) create a table in Postgres of PostGIS type "Geometry"
> If I change the command to:
> ogr2ogr
>   -progress
>   -lco OVERWRITE=YES
>   -dim XY
> *  -nlt PROMOTE_TO_MULTI*
> dbname=geodata"
>   FREDSKOV.TAB
> I would expect the table to change the PostGIS type to "MultiPolygon".
> However it still is registered as "Geometry".
> Checking the table using SQL command:
> SELECT ST_geometrytype(wkb_geometry), count(*) FROM mat.fredskov group by 1
> affirms, that all geometries now is of type "ST_MultiPolygon".
> AFAIK, this is a new behaviour. Or what ?
> Postgres/Postgis version : 13.2,  3.1
> OGR2OGR version:  both 3.4 andf 3.6 dev.
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220725/5c6e9da3/attachment.htm>
