[gdal-dev] VRT dataset to text in-memory?
    Even Rouault
    even.rouault at spatialys.com
    Sun Mar  6 03:18:52 PST 2022
Michael,
yes you can get the VRT XML text with:
poVRTDS->GetMetadata("xml:VRT")[0]
If you can submit a pull request documenting that, that would be welcome
Even
Le 03/03/2022 à 11:14, Michael Sumner a écrit :
> Hello, reading the raster VRT tutorial
> https://gdal.org/drivers/raster/vrt.html#creation-of-vrt-datasets
> with this code:
> int   nBand;
> GDALDriver *poDriver = (GDALDriver *) GDALGetDriverByName( "VRT" );
> GDALDataset *poSrcDS, *poVRTDS;
> poSrcDS = (GDALDataset *) GDALOpenShared( pszSourceFilename,
> GA_ReadOnly );
> poVRTDS = poDriver->CreateCopy( "", poSrcDS, FALSE, NULL, NULL, NULL );
> Is there a way to obtained the VRT XML text representing poVRTDS
> without writing to an actual file?
> Sorry if this is obvious, haven't been able to find an example that
> does what I want. I've seen examples using GetMetadataItem from a band
> for parts of the XML, but can't see how to get the entire thing.
> Thanks for your help.
> Best, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220306/5aa7e3fa/attachment.html>
