[gdal-dev] About COG with multiple bands
Even Rouault even.rouault at spatialys.com
Mon May 2 01:09:51 PDT 2022
Javier,
up to now, GDAL has restricted the COG definition to pixel interleaved
organization, a bit artificially admittedly. This issue was recorded in
https://github.com/opengeospatial/CloudOptimizedGeoTIFF/issues/3 .
There's no way to efficiently extract a subset of bands with pixel
interleaved organization.
Even
Le 01/05/2022 à 11:10, Javier Jimenez Shaw a écrit :
> Hi
> In the event "Cloud Native Geospatial" Chris mentioned that a COG file
> allows to extract just a few bands. For instance, from a satellite
> image with 12 bands, you could extract only red, green and blue, not
> needing to download all the bands. In this example it would be a
> reduction factor of 4.
> If I understand correctly from
> https://gdal.org/drivers/raster/cog.html "Pixel interleaving for
> multi-band dataset" the optimization mentioned above could not be
> possible. Am I right? Is there any efficient way to read just one band?
> Thanks,
> Javier.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220502/5add5cb7/attachment.htm>
