[gdal-dev] CMake: undefined reference to symbol dlerror
Even Rouault even.rouault at spatialys.com
Mon May 2 01:29:23 PDT 2022
Le 29/04/2022 à 11:30, Javier Jimenez Shaw a écrit :
> We have a link problem on Linux when using GDAL transiently. If we
> link the unit tests for a library which depends on GDAL, i.e. an
> executable which transiently depends on GDAL through our library, we
> get the following linker error:
> /usr/bin/ld:
> libs/ioimage/tests/CMakeFiles/tests_unit_ioimage.dir/unit/writers/test_geoTiffWriter.cpp.o:
> undefined reference to symbol 'dlerror@@GLIBC_2.2.5'
> /usr/bin/ld: /lib/x86_64-linux-gnu/libdl.so.2: error adding symbols:
> DSO missing from command line
> We need to add -ldl to the linker line after GDAL in order to resolve
> the linker problem. This can be done when adding the property
>   INTERFACE_LINK_LIBRARIES "dl"
> to the GDAL::GDAL imported target in GDAL-targets-release.cmake (this
> is a generated file); apparently it is not enough to add dl to the
> IMPORTED_LINK_DEPENDENT_LIBRARIES_RELEASE property.
> Does GDAL depend publicly on dl?
Not that I'm aware of.
Our CI runs ./autotest/postinstall/test_cmake.sh which in particular has
a ./autotest/postinstall/test_cpp/CMakeLists.txt that has GDAL has a
dependency
Perhaps you could check how your setup is different from that ?
> We do not find the proper way to patch GDAL's CMake code to add that
> dependency in the generated config file.
> Thanks
> Javier
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220502/be3d1a8f/attachment.htm>
