[gdal-dev] Building with cmake
Greg Troxel gdt at lexort.com
Sun May 8 03:37:28 PDT 2022
Paul Harwood <runette at gmail.com> writes:
> I get that error message when I try to use the source directory as the
> build directory.
> With cmake, it is better to use a different folder structure for the build
> - if I remember correctly something like running cmake in a clean version
> of the repository but using ..
> cmake -S . -B ../build
or
  mkdir build
  cd build
  cmake ..
While I completely agree that it's better to buse a build directory, I
think it's a bug if cmake in the source dir fails, unless it is
documented not to work and it bails out early with a nice error message.
There also should be a checked-in clean script that removes all
cmake-generated files, sort of like "make maintainerclean".
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220508/401cc358/attachment.sig>
