[gdal-dev] GDAL 3.5.0rc2 available (Re: GDAL 3.5.0 release candidate available)
Even Rouault even.rouault at spatialys.com
Mon May 9 02:47:47 PDT 2022
I've issued a RC2 with the following changes:
- CMake: fix build of NITF driver if rebuilding after disabling JPEG driver
- port/cpl_recode_iconv.cpp: fix invalid cast error with uclibc (#5684)
- PNG: report cause when unable to create file
- PCIDSK: fix build on 32-bit architectures on Debian (fixes #5694)
- TileDB: compiler warning fix on 32bit
- ogr2ogr: avoid potential nullptr deref (CID 1488679)
- netCDF: add support for writing/reading geolocation array without a
grid_mapping variable
Updated archives:
   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.xz
   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.gz
   https://download.osgeo.org/gdal/3.5.0/gdal350rc2.zip
https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.tar.gz
   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.zip
Even
Le 06/05/2022 à 15:06, Even Rouault a écrit :
> Hi,
> I have prepared a GDAL/OGR 3.5.0 release candidate.
> NEWS at:
>   https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
> Note the first item about the new CMake build system, and the
> deprecation of the autoconf & nmake build systems that will be removed
> in GDAL 3.6.0
> Pick up an archive among the following ones (by ascending size):
>   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>   https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
> A snapshot of the gdalautotest suite is also available :
> https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
> A snapshot of the documentation is at:
>   https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
> The GDAL-GRASS plugin sources and release process has been moved to
> https://github.com/OSGeo/gdal-grass
> I'll call for a vote promoting it to next week if no serious problems
> are reported before.
> The "release/3.5" branch has been created for all bug fixes related to
> 3.5.x. master is now targetting 3.6.0dev.
> Best regards,
> Even
http://www.spatialys.com
