[gdal-dev] GDAL 3.5.0rc3 available (Re: GDAL 3.5.0 release candidate available)
Even Rouault even.rouault at spatialys.com
Tue May 10 03:01:47 PDT 2022
Sandro,
can you check if https://github.com/OSGeo/gdal/pull/5698 fixes your issue ?
Even
Le 10/05/2022 à 11:48, Sandro Mani a écrit :
> Hi
> Testing RC3 on Fedora rawhide, the native build with cmake build fine.
> The mingw build OTOH fails with
> /home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:4556:29:
> error: invalid user-defined conversion from 'const
> cpl::IVSIS3LikeFSHandler::Sync(const char*, const char*, const char*
> const*, GDALProgressFunc, void*,
> char***)::<lambda(void*)>::<lambda(double, const char*, void*)>' to
> 'GDALProgressFunc' {aka 'int (__attribute__((stdcall)) *)(double,
> const char*, void*)'} [-fpermissive]
>  4556 |                             progressFunc, &progressData) )
> /home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:4473:39:
> note: candidate is: 'cpl::IVSIS3LikeFSHandler::Sync(const char*, const
> char*, const char* const*, GDALProgressFunc, void*,
> void*)>::operator int (*)(double, const char*, void*)() const' (near
> match)
>  4473 |             const auto progressFunc = [](double pct, const
> char*, void* pProgressDataIn)
> note:   no known conversion from 'int (*)(double, const char*, void*)'
> to 'GDALProgressFunc' {aka 'int (__attribute__((stdcall)) *)(double,
> /home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/port/cpl_vsil_s3.cpp:3529:39:
> note:   initializing argument 6 of 'bool
> cpl::IVSIS3LikeFSHandler::CopyFileA(VSILFILE*, vsi_l_offset, const
> char*, const char*, CSLConstList, GDALProgressFunc, void*)'
>  3529 |                      GDALProgressFunc pProgressFunc,
> make[2]: *** [port/CMakeFiles/cpl.dir/build.make:1010:
> port/CMakeFiles/cpl.dir/cpl_vsil_s3.cpp.obj] Error 1
> make[2]: Leaving directory
> '/home/sandro/rpmbuild/BUILD/gdal-3.5.0-fedora/build_win32'
> make[2]: *** Waiting for unfinished jobs....
> make[2]: Entering directory
> I'm investigating.
> Thanks
> Sandro
> On 10.05.22 00:27, Sean Gillies wrote:
>> Thanks, Even. RC3 compiles and I don't see any regressions from
>> rasterio's perspective. Looking forward to the new release!
>> On Mon, May 9, 2022 at 1:30 PM Even Rouault
>> <even.rouault at spatialys.com> wrote:
>>     Sean,
>>     I've issue a rc3 with a fix for that issue:
>>     https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.xz
>>     https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc3.tar.gz
>>     https://download.osgeo.org/gdal/3.5.0/gdal350rc3.zip
>>     Even
>>     Le 09/05/2022 à 20:47, Sean Gillies a écrit :
>>>     Hi Even,
>>>     I'm still using the legacy configure script and have found that
>>>     ogrmvtdataset.cpp doesn't compile on my system due to
>>>     In file included from ogrmvtdataset.cpp:43:
>>>     .../ogr_geos.h:40:12: fatal error: geos_c.h: No such file or
>>>     directory
>>>     This is GDAL 3.5.0rc2. I haven't tried the earlier pre-releases.
>>>     GDAL 3.4.3 compiled and installed on the same computer using the
>>>     same script, which is:
>>>     LD_LIBRARY_PATH=/home/seangillies/local/lib ./configure
>>>     --prefix=/home/seangillies/local --with-curl
>>>     --with-geos=/home/seangillies/local/bin/geos-config
>>>     --with-proj=/home/seangillies/local
>>>     On Mon, May 9, 2022 at 3:48 AM Even Rouault
>>>         Hi,
>>>         I've issued a RC2 with the following changes:
>>>         - CMake: fix build of NITF driver if rebuilding after
>>>         disabling JPEG driver
>>>         - port/cpl_recode_iconv.cpp: fix invalid cast error with
>>>         uclibc (#5684)
>>>         - PNG: report cause when unable to create file
>>>         - PCIDSK: fix build on 32-bit architectures on Debian (fixes
>>>         #5694)
>>>         - TileDB: compiler warning fix on 32bit
>>>         - ogr2ogr: avoid potential nullptr deref (CID 1488679)
>>>         - netCDF: add support for writing/reading geolocation array
>>>         without a
>>>         grid_mapping variable
>>>         Updated archives:
>>>         https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.xz
>>>         https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc2.tar.gz
>>>         https://download.osgeo.org/gdal/3.5.0/gdal350rc2.zip
>>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.tar.gz
>>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc2.zip
>>>         Even
>>>         Le 06/05/2022 à 15:06, Even Rouault a écrit :
>>>         > Hi,
>>>         > I have prepared a GDAL/OGR 3.5.0 release candidate.
>>>         > NEWS at:
>>>         > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>>>         > Note the first item about the new CMake build system, and the
>>>         > deprecation of the autoconf & nmake build systems that
>>>         will be removed
>>>         > in GDAL 3.6.0
>>>         > Pick up an archive among the following ones (by ascending
>>>         size):
>>>         > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>>>         > https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>>>         > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>>>         > A snapshot of the gdalautotest suite is also available :
>>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>>>         https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>>>         > A snapshot of the documentation is at:
>>>         > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>>>         > The GDAL-GRASS plugin sources and release process has been
>>>         moved to
>>>         > https://github.com/OSGeo/gdal-grass
>>>         > I'll call for a vote promoting it to next week if no
>>>         serious problems
>>>         > are reported before.
>>>         > The "release/3.5" branch has been created for all bug
>>>         fixes related to
>>>         > 3.5.x. master is now targetting 3.6.0dev.
>>>         > Best regards,
>>>         > Even
>> Sean Gillies
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/8d2c9cc0/attachment.htm>
