[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Sean Gillies sean.gillies at gmail.com
Tue May 10 14:02:13 PDT 2022
Hi Even,
I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos. It
occurs when I use https://github.com/matthew-brett/delocate to relocate
GDAL and its dependencies into rasterio wheels.
The error:
ERROR:delocate.libsana:
@rpath/libproj.25.dylib not found:
Needed by: /usr/local/lib/libgdal.31.dylib
Search path:
ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
Here is its context:
https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025
I searched the GDAL tracker for related issues and only found
https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
related, but it also looks like the fix is cmake specific and isn't
available for autotools builds. Is that correct?
On Tue, May 10, 2022 at 8:13 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I've issued a rc4 with the following fixes w.r.t rc3:
> * fix build error with CMake >= 3.10.2 and < 3.11
> * fix build errors with Fedora mingw32
> Updated archives:
>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>    https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
> Even
> Le 06/05/2022 à 15:06, Even Rouault a écrit :
> > Hi,
> > I have prepared a GDAL/OGR 3.5.0 release candidate.
> > NEWS at:
> >   https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
> > Note the first item about the new CMake build system, and the
> > deprecation of the autoconf & nmake build systems that will be removed
> > in GDAL 3.6.0
> > Pick up an archive among the following ones (by ascending size):
> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
> >   https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
> > A snapshot of the gdalautotest suite is also available :
> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
> >   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
> > A snapshot of the documentation is at:
> >   https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
> > The GDAL-GRASS plugin sources and release process has been moved to
> > https://github.com/OSGeo/gdal-grass
> > I'll call for a vote promoting it to next week if no serious problems
> > are reported before.
> > The "release/3.5" branch has been created for all bug fixes related to
> > 3.5.x. master is now targetting 3.6.0dev.
> > Best regards,
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/cfeeea3f/attachment.htm>
