[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Sean Gillies sean.gillies at gmail.com
Tue May 10 15:18:16 PDT 2022
Thanks, Alan!
I feel like we're in the middle of going backwards to go forwards when it
comes to FOSS4G software builds.
On Tue, May 10, 2022 at 4:05 PM Alan Snow <alansnow21 at gmail.com> wrote:
> This might be a helpful reference:
> https://github.com/pyproj4/pyproj-wheels/issues/45
> On Tue, May 10, 2022, 4:33 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Sean,
>> So your issue is with a GDAL autoconf build. I can't see any significant
>> changes in configure.ac between GDAL 3.5.0 and 3.4.0 related to rpath.
>> This has probably not changed in years. I do see in your logs that the
>> linking line of GDAL has a
>>  -rpath /usr/local/lib
>> and that there's a /usr/local/lib/libproj.25.dylib file
>> But perhaps the issue is more with the PROJ CMake build (hypothesis that
>> you could check by testing with a PROJ 8.2.1 autoconf build) ? I don't
>> know... Mac + rpath is hostile territory for me.
>> Does running a GDAL binary, like gdalinfo, works before using that
>> delocate module ?
>> Yes 5413 is CMake specific.
>> Even
>> Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
>> Hi Even,
>> I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos. It
>> occurs when I use https://github.com/matthew-brett/delocate to relocate
>> GDAL and its dependencies into rasterio wheels.
>> The error:
>> ERROR:delocate.libsana:
>> @rpath/libproj.25.dylib not found:
>> Needed by: /usr/local/lib/libgdal.31.dylib
>> Search path:
>> ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
>> Here is its context:
>> https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025
>> I searched the GDAL tracker for related issues and only found
>> https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
>> related, but it also looks like the fix is cmake specific and isn't
>> available for autotools builds. Is that correct?
>> On Tue, May 10, 2022 at 8:13 AM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> Hi,
>>> I've issued a rc4 with the following fixes w.r.t rc3:
>>> * fix build error with CMake >= 3.10.2 and < 3.11
>>> * fix build errors with Fedora mingw32
>>> Updated archives:
>>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>>>    https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
>>> Even
>>> Le 06/05/2022 à 15:06, Even Rouault a écrit :
>>> > Hi,
>>> > I have prepared a GDAL/OGR 3.5.0 release candidate.
>>> > NEWS at:
>>> >   https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>>> > Note the first item about the new CMake build system, and the
>>> > deprecation of the autoconf & nmake build systems that will be removed
>>> > in GDAL 3.6.0
>>> > Pick up an archive among the following ones (by ascending size):
>>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>>> >   https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>>> > A snapshot of the gdalautotest suite is also available :
>>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>>> >   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>>> > A snapshot of the documentation is at:
>>> >   https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>>> > The GDAL-GRASS plugin sources and release process has been moved to
>>> > https://github.com/OSGeo/gdal-grass
>>> > I'll call for a vote promoting it to next week if no serious problems
>>> > are reported before.
>>> > The "release/3.5" branch has been created for all bug fixes related to
>>> > 3.5.x. master is now targetting 3.6.0dev.
>>> > Best regards,
>>> > Even
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Sean Gillies
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/a1461730/attachment.htm>
