[gdal-dev] Sign conversion error in ogr_feature.h
Even Rouault even.rouault at spatialys.com
Thu May 12 01:53:28 PDT 2022
Andrew,
Le 12/05/2022 à 10:22, Andrew C Aitchison a écrit :
> I fear this should probably go into 3.5.0.
Althoug annoying, this is just a warning. I see this is as a 3.5.1
material, otherwise 3.5.0 will never be released.
> clang++-14 -Wsign-conversion doesn't like the definitions of the new
> GetFieldDefnUnsafe() functions
> Sorry about the non-line-wrap;
> I hope to preserve the 2D intent of the warning messages:
> /usr/lib/llvm-14/bin/clang++ -DDONT_DEPRECATE_SPRINTF
> -DGDAL_CMAKE_BUILD -DGDAL_COMPILATION -DHAVE_AVX_AT_COMPILE_TIME
> -DHAVE_SSE_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/apps
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/alg
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/gcore
> -I/home/werdna/gdal3.5.0/gdal-3.5.0-llvm/gcore
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/port
> -I/home/werdna/gdal3.5.0/gdal-3.5.0-llvm/port
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/ogr
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogrsf_frmts
> -I/home/werdna/gdal3.5.0/gdal-3.5.0/frmts -fvisibility=hidden -g -fPIC
> -Wsign-conversion -fno-operator-names -Wzero-as-null-pointer-constant
> -std=gnu++11 -MD -MT
> ogr/ogrsf_frmts/dxf/CMakeFiles/ogr_DXF.dir/ogrdxf_ocstransformer.cpp.o
> -MF CMakeFiles/ogr_DXF.dir/ogrdxf_ocstransformer.cpp.o.d -o
> CMakeFiles/ogr_DXF.dir/ogrdxf_ocstransformer.cpp.o -c
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogrsf_frmts/dxf/ogrdxf_ocstransformer.cpp
> In file included from
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogrsf_frmts/dxf/ogrdxf_ocstransformer.cpp:31:
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogrsf_frmts/dxf/ogr_dxf.h:35:
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogrsf_frmts/ogrsf_frmts.h:35:
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogr_feature.h:310:119: warning:
> implicit conversion changes signedness: 'int' to
> 'std::vector::size_type' (aka 'unsigned long') [-Wsign-conversion]
>     OGRFieldDefn       *GetFieldDefnUnsafe( int i ) { if(
> apoFieldDefn.empty() ) GetFieldDefn(i); return apoFieldDefn[i].get(); }
> /home/werdna/gdal3.5.0/gdal-3.5.0/ogr/ogr_feature.h:311:125: warning:
>     const OGRFieldDefn *GetFieldDefnUnsafe( int i ) const { if(
> 2 warnings generated.
> I think that ogr/ogrfeaturedefn.cpp at least may have to be changed as
> well.
> Is the correct fix to change "int i" to "std::vector::size_type i" ?
Fix queued in https://github.com/OSGeo/gdal/pull/5712 (I didn't change
the signature, but the[] access, so it is the same as other similar methods)
http://www.spatialys.com
