[gdal-dev] GDAL 3.5.0 is released
    Mateusz Loskot
    mateusz at loskot.net
    Fri May 13 06:57:49 PDT 2022
On Fri, 13 May 2022 at 14:29, Even Rouault <even.rouault at spatialys.com> wrote:
> The 3.5.0 release is a new feature release with the following highlights:
> * [RFC 84](https://gdal.org/development/rfc/rfc84_cmake.html):
>    Addition of a CMake build system, which deprecates the existing
>    autoconf/automake and nmake build systems, that will be removed
Awesome!
Thank you very much to all involved in making the CMake into GDAL!
The initial attempt (codename: cmake4gdal) was made around 2011
by folks at Kitware... :)
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
