[gdal-dev] GDAL_RETILE dataset is illegal
Lorenzo Di Giacomo loridigia at gmail.com
Wed May 25 07:24:05 PDT 2022
Hi, when i try to do gdal_retile -v -pyramidOnly -r bilinear ... this error
occurs:
ERROR 1: Attempt to create 2x0 dataset is illegal,sizes must be larger than
zero.
My Tiff is the following (gdalinfo):
Driver: GTiff/GeoTIFF
Files: /Users/lollo/Desktop/TRANSFORMOUT/Aegean_12km_WRF_WAM_220523-00.tiff
Size is 74, 62
Coordinate System is:
GEOGCRS["WGS 84",
    DATUM["World Geodetic System 1984",
        ELLIPSOID["WGS 84",6378137,298.257223563,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433]],
    CS[ellipsoidal,2],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
    ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
Origin = (22.029000000000003,41.158000000000001)
Pixel Size = (0.108000000000000,-0.108000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  22.0290000,  41.1580000) ( 22d 1'44.40"E, 41d 9'28.80"N)
Lower Left  (  22.0290000,  34.4620000) ( 22d 1'44.40"E, 34d27'43.20"N)
Upper Right (  30.0210000,  41.1580000) ( 30d 1'15.60"E, 41d 9'28.80"N)
Lower Right (  30.0210000,  34.4620000) ( 30d 1'15.60"E, 34d27'43.20"N)
Center      (  26.0250000,  37.8100000) ( 26d 1'30.00"E, 37d48'36.00"N)
Band 1 Block=74x1 Type=Float64, ColorInterp=Gray
  NoData Value=-123456.789000000004
Band 2 Block=74x1 Type=Float64, ColorInterp=Undefined
(Other 724 bands)
Why does this happen? What are the specs of the tiff that make this
happens? Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220525/bc53b355/attachment.htm>
