[gdal-dev] ogr2ogr Postgres upload performance
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri May 27 06:12:47 PDT 2022
If the problem is that PG_USE_COPY is applied only to the first layer of the multi-table GeoPackage then I would make a test by writing a separate ogr2ogr command for each layer.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Alexandre Gacon
Lähetetty: maanantai 23. toukokuuta 2022 17.39
Vastaanottaja: Jan Heckman <jan.heckman at gmail.com>
Kopio: gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] ogr2ogr Postgres upload performance
I will try this way. To turn of SI creation : SPATIAL_INDEX=NONE
Le lun. 23 mai 2022 à 15:15, Jan Heckman <jan.heckman at gmail.com<mailto:jan.heckman at gmail.com>> a écrit :
Perhaps the spatial index update (in de DB) slows the insertion.
It might be more efficient to not create the SI in the first run,
then insert more rows and create the SI after all is done.
I don't know how to turn off SI creation in the command line.
On Mon, May 23, 2022 at 3:04 PM Alexandre Gacon <alexandre.gacon at gmail.com<mailto:alexandre.gacon at gmail.com>> wrote:
Hello,
I am using ogr2ogr to upload data from several geopackages to a postgis database. Some tables contain thousands of rows (buildings for example).
The import of the first file is quite fast (tables are created for the first file so PG_USE_COPY is used) but the following file is much slower (using INSERT instead of COPY).
How could I data insertion for the other files? Force PG_USE_COPY ? Increase the value of GT ? Postpone spatial index creation ?
Should I concatenate all the geopackages first and then insert the data in Postgis?
Thank you for your help
Alexandre Gacon
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C6fa46f068e26430b7f9908da3cca0f7a%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637889135792134784%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=%2Bmpy0HNtP0mb%2FzvSpD4E9U0Cipge3NviqQs%2B7D6hZcQ%3D&reserved=0>
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220527/2c91699d/attachment.htm>
