[gdal-dev] Command line /python syntax differences
Jonas Ardö jonas.ardo at nateko.lu.se
Wed Nov 2 03:53:04 PDT 2022
Dear gdal-gurus,
I am new to using gdal via Python.
As the command line arguments/keywords differ from command prompt mode
and Python-mode (for example for example is *-r* in gdal_translate  the
same  as *resampleAlg* in gdal.Translate in Python).
I find it tricky to find arguments/keywords in Python.
How can all options/full syntax for gdal-pythons commands be listed as
done here
<https://gis.stackexchange.com/questions/352643/gdal-translate-in-python-where-do-i-find-how-to-convert-the-command-line-argum>
Where they also refer tohttps://gdal.org/python/ which do not exist.
Any other (full/completed) online resource for this?
Can "pydoc -g osgeo" be used?
Are the The gdal-dev Archives searchable?
Regards
/Jonas, Lund University, Sweden
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221102/150dde52/attachment.htm>
