[gdal-dev] org2org
Leber, Thorsten Thorsten.Leber at hensoldt.net
Wed Nov 9 03:02:16 PST 2022
Hi All,
I am trying to use org2org with the following command:
ogr2ogr -f "ESRI Shapefile" C:\RenderTest\raster_clipper_and.shp PG:"host=10.49.20.42 port=5432 user=tilemill password=test dbname=nextgen" -sql "SELECT "name", "left", top, "right", bottom FROM grids.grid_1_25grad WHERE ST_Intersects(geom, (SELECT geom FROM countries.geometries_boundary_buffer_10km('and'))) AND NOT ST_Touches(geom, (SELECT geom FROM countries.geometries_boundary_buffer_10km('and')))" -s_srs EPSG:4326 -t_srs EPSG:4326 -overwrite -lco ENCODING=utf8
I expect in the output folder 5 files
[cid:image001.png at 01D8F432.E187B8A0]
But I receive a warning:
Warning 1: layer names ignored in combination with -sql.
And get only 3 files
[cid:image002.png at 01D8F433.27BC9750]
I am missing the .shp and the .shx file. Is there something wrong in my command?
KR
Thorsten
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/e6dcfab6/attachment.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/e6dcfab6/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/e6dcfab6/attachment-0001.png>
