[gdal-dev] gdal2tiles: RuntimeError: Cannot find coordinate operations from `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere"
Terra Frost terrafrost at gmail.com
Wed Nov 9 08:54:57 PST 2022
I have two TIFs that I'm able to run gdal2tiles on without issue, however,
when I do gdal_merge I am unable to do gdal2tiles on the result. When I did
gdal_merge on the two TIFs I got this warning:
Warning 1: PROJ: proj_create_from_database: Cannot find proj.db
Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF keys
is not the same as the one from the EPSG registry, which may cause issues
during reprojection operations. Set GTIFF_SRS_SOURCE configuration option
to EPSG to use official parameters (overriding the ones from GeoTIFF keys),
or to GEOKEYS to use custom values from GeoTIFF keys and drop the EPSG code.
0...10...20...30...40...50...60...70...80...90...100 - done.
Despite the warning the two TIFs merged without issue, however, when I try
to run gdal2tiles on the merged TIF I get this error:
  File "/usr/bin/gdal2tiles.py", line 16, in <module>
    sys.exit(main(sys.argv))
  File "/usr/lib/python3/dist-packages/osgeo_utils/gdal2tiles.py", line
3314, in main
    single_threaded_tiling(input_file, output_folder, options)
3229, in single_threaded_tiling
    conf, tile_details = worker_tile_details(input_file, output_folder,
options)
3145, in worker_tile_details
    gdal2tiles.open_input()
1797, in open_input
    self.warped_input_dataset = reproject_dataset(
987, in reproject_dataset
    to_dataset = gdal.AutoCreateWarpedVRT(from_dataset,
  File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line 3976, in
AutoCreateWarpedVRT
    return _gdal.AutoCreateWarpedVRT(*args)
`ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",EDATUM[""],CS[Cartesian,2],AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
to `EPSG:3857'
free(): invalid pointer
Aborted
When I do gdalinfo on the merged TIF I get this:
Corner Coordinates:
Upper Left  (-10880978.065, 3538629.874)
Lower Left  (-10880978.065, 3537702.774)
Upper Right (-10880302.765, 3538629.874)
Lower Right (-10880302.765, 3537702.774)
Center      (-10880640.415, 3538166.324)
When I do gdalinfo on the two TIFs that I merged I get this:
Upper Left  (-10880811.355, 3538629.874)
Lower Left  (-10880811.355, 3538052.574)
Upper Right (-10880302.755, 3538629.874)
Lower Right (-10880302.755, 3538052.574)
Center      (-10880557.055, 3538341.224)
...and...
Upper Left  (-10880978.065, 3538273.090)
Lower Left  (-10880978.065, 3537702.790)
Upper Right (-10880474.265, 3538273.090)
Lower Right (-10880474.265, 3537702.790)
Center      (-10880726.165, 3537987.940)
Any ideas?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/f827e616/attachment.htm>
