[gdal-dev] org2org
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Nov 10 00:25:58 PST 2022
Sorry to pollute this list (again !) with non GDAL related information,
however -
I made a mistake in my answer about the SQL statement and the nerd part
of my brain just won't let go. So:
  * The SQL where-part  contains a combination of st_intersects (geom,
    /..some geometry resulting function../) and not st_touches (geom,
    /..same geometry resulting function../)
    "intersects" and "not touches" is equivalent to "within", so you can
    probably rewrite the where part to: *
    WHERE ST_Within(geom, (SELECT geom FROM
    countries.geometries_boundary_buffer_10km('and')*))
The above is /not/ correct. The equivalent to "intersects and not
touches" is "within or overlaps". The where statement should be:
*WHERE ST_Within(geom, (SELECT geom FROM
countries.geometries_boundary_buffer_10km('and')*)) *OR*
*ST_Overlaps(geom, (SELECT geom FROM
Which is marginally better than the original where.
But if you read the entire SQL statement, I would assume the purpose
would be something like: "/Fetch all gridcells that is wihtin a 10 km.
distance from a set of countries"//./
In that case the where part could  be simplified (and running
considerably faster) by using ST_DWithin:
*SELECT
     a.name,
     a.left,
     a.top,
     a.right,
     a.bottom,
     a.geom
FROM grids.grid_1_25grad a
JOIN countries.table_with_countries b ON ST_DWIthin (a.geom, b.geom,
10000.0)*
If the 2 tables involved has the same SRID (using meters as distance
unit) and the spatial columns is of type geometry
Med venlig hilsen / Best regards
Bo Victor Thomsen
Den 09-11-2022 kl. 21:55 skrev Bo Victor Thomsen:
> Thorsten -
> It seems that your workstation has QGIS installed (The picture of file
> explorer shows a QGIS icon for one of the shape files). Why dont you
> use the DBManager function in QGIS to test your SQL ?
> Sanitized version of the select:
> SELECT
>     name,
>     left,
>     top,
>     right,
>     bottom,
>     geom
> WHERE
>     ST_Intersects(geom, (SELECT geom FROM
> countries.geometries_boundary_buffer_10km('and'))) AND NOT
>     ST_Touches   (geom, (SELECT geom FROM
> countries.geometries_boundary_buffer_10km('and')))*
>   * You are selecting features from table /grids.grid_1_25grad/. The
>     name of the table indicates it contains grid cells - like the ones
>     you show in the picture.
>     /..some geometry resulting funtion../) and not st_touches (geom,
>     /..same geometry resulting funtion../)
>     can probably rewrite the where part to: *
> Bo Victor Thomsen
> Den 09-11-2022 kl. 14:53 skrev Rahkonen Jukka:
>> Hi,
>> You are selecting data from table grids.grid_1_25grad. I suppose that
>> table contains grid polygons. By your image you seem to want some
>> buffered geometry. Spend some time for thinking about what data do
>> you want and where to get it. You can test your queries with for
>> example pgAdmin that can preview the geometries. Or use OpenJUMP that
>> is an excellent tool for visualizing PostGIS query results.
>> -Jukka Rahkonen-
>> *Lähettäjä:*Leber, Thorsten <Thorsten.Leber at hensoldt.net>
>> *Lähetetty:* keskiviikko 9. marraskuuta 2022 15.46
>> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
>> *Aihe:* AW: org2org
>> Hi Jukka,
>> with geometry al 5 files are created
>> ogr2ogr -f "ESRI Shapefile" C:\RenderTest\raster_clipper_and.shp
>> PG:"host=10.49.20.42 port=5432 user=tilemill password=test
>> dbname=nextgen" -sql "SELECT \""name\"", \""left\"", top,
>> \""right\"", bottom, geom FROM grids.grid_1_25grad WHERE
>> ST_Touches(geom, (SELECT geom FROM
>> countries.geometries_boundary_buffer_10km('and')))" -s_srs
>> "EPSG:4326" -t_srs "EPSG:4326" -overwrite -lco ENCODING=utf8
>> but it looks strange
>> I would expect this
>> Thorsten
>> *Von:*Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
>> *Gesendet:* Mittwoch, 9. November 2022 13:10
>> *An:* Leber, Thorsten <Thorsten.Leber at hensoldt.net>
>> *Betreff:* Re: org2org
>> This message was sent from outside of HENSOLDT. Please do not click
>> on links or open attachments unless you validate the source of this
>> email and know the content is safe.
>> Hi,
>> Try to add a geometry into the selection -sql "SELECT \""name\"",
>> \""left\"", top, \""right\"", bottom FROM..
>> -Jukka-
>> *Lähetetty:* keskiviikko 9. marraskuuta 2022 13.53
>> *Aihe:* AW: org2org
>> \""right\"", bottom FROM grids.grid_1_25grad WHERE
>> countries.geometries_boundary_buffer_10km('and')))" -s_srs EPSG:4326
>> -t_srs EPSG:4326 -overwrite -lco ENCODING=utf8
>> this works now without any warning but still only 3 files in output
>> folder
>> *Gesendet:* Mittwoch, 9. November 2022 12:21
>> *An:* Leber, Thorsten <Thorsten.Leber at hensoldt.net>;
>> gdal-dev at lists.osgeo.org
>> Hi,
>> Does the SQL part work with a tool like pgAdmin? Notice that the
>> inner double quotes must be escaped as \” in the ogr2ogr command or
>> otherwise they will truncate the -sql parameter. And it seems that
>> you did not select the geometry field. Generally I would suggest to
>> start with a simple SQL and add complexity once you have gotten a
>> good result. Suggestion includes testing with easy table names first
>> before forwarding to names like
>> countries.geometries_boundary_buffer_10km('and').
>> -Jukka Rahkonen-
>> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
>> *Leber, Thorsten
>> *Lähetetty:* keskiviikko 9. marraskuuta 2022 13.02
>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>> *Aihe:* [gdal-dev] org2org
>> Hi All,
>> I am trying to use org2org with the following command:
>> dbname=nextgen" -sql "SELECT "name", "left", top, "right", bottom
>> FROM grids.grid_1_25grad WHERE ST_Intersects(geom, (SELECT geom FROM
>> I expect in the output folder 5 files
>> But I receive a warning:
>> Warning 1: layer names ignored in combination with -sql.
>> And get only 3 files
>> I am missing the .shp and the .shx file. Is there something wrong in
>> my command?
>> KR
>> Thorsten
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221110/b00d3699/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221110/b00d3699/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221110/b00d3699/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221110/b00d3699/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221110/b00d3699/attachment-0007.png>
