[gdal-dev] GDAL 3.6.0 patch for building on iOS (and Mac Catalyst)
Even Rouault even.rouault at spatialys.com
Fri Nov 11 17:07:08 PST 2022
Le 12/11/2022 à 02:00, Nik Sands a écrit :
> Hi GDAL devs
> It appears as though ‘pread64’, introduced in 3.6.0, has broken building on iOS in the same way that other ‘…64’ errors used to occur on version 3.5.0 before being patched for 3.5.2.
> The attached patch (text content also pasted below) allows the build to continue past that point for iOS (and Mac Catalyst).  I’m just an ignorant hobbyist who doesn’t really understand a lot of this stuff, so please check that what I’ve done here is correct!  :-)  If it’s all OK, then please apply this (or similar) patch for the next release.
Patch queued in https://github.com/OSGeo/gdal/pull/6673
Thanks
http://www.spatialys.com
