[gdal-dev] Build 3.6.0 for iOS fails - _sqlite3_progress_handler error
Nik Sands nik at nixanz.com
Fri Nov 11 19:17:52 PST 2022
Hi again,
I have now resolved this issue by rebuilding SQLite with the SQLITE_OMIT_PROGRESS_CALLBACK=OFF
GDAL 3.6.0 will now build successfully with my updated buiild of SQLite.
Sorry to have troubled you with this one.
NB:  This may still be worth pursuing within GDAL, since SQLite explicitly recommend building with this omitted, as per:  https://www.sqlite.org/compile.html
If you still wished to pursue a GDAL fix for possibility of missing sqlite3_progress_handler, then it’s worth noting that it’s not an iOS issue, as far as I know, since I was not using iOS default SQLite.
Cheers,
Nik.
> On 12 Nov 2022, at 1:51 pm, Nik Sands <nik at nixanz.com> wrote:
> Hi Even,
> Sorry, I should have mentioned that I’m not using the standard iOS/macOS SQLite (because it does not include RTREE extension which seems to be required for GDAL).
> I’m using a CMAKE compatible SQLite from:  https://github.com/azadkuh/sqlite-amalgamation (which was working fine with GDAL 3.5.2)
> I tried building SQLite with:
> 		-DSQLITE_OMIT_PROGRESS_CALLBACK=OFF
> but it logged that it was ignoring this (not sure why, when it works OK when I specify other options similarly, such as -DSQLITE_OMIT_DECLTYPE=OFF)
> Anyhow…
> The patch build of GDAL did not resolve the problem, although the output is slightly different.  I still got this error (re-pasted from current build, below).
> I’m also trying to figure out how to get SQLITE_OMIT_PROGRESS_CALLBACK disabled in my SQLite build, which may be a better way to go?  Got to figure out the right CMakeLists.txt changes (in SQLite) for this.
> Cheers,
> Nik.
> Consolidate compiler generated dependencies of target gdal_unit_test
> [ 94%] Linking CXX executable gdal_unit_test.app/gdal_unit_test
> Undefined symbols for architecture arm64:
>   "_sqlite3_progress_handler", referenced from:
>       OGRGeoPackageTableLayer::GetGeometryTypes(int, int, int&, int (*)(double, char const*, void*), void*) in libgdal.a(ogrgeopackagetablelayer.cpp.o)
> ld: symbol(s) not found for architecture arm64
> clang: error: linker command failed with exit code 1 (use -v to see invocation)
> make[2]: *** [autotest/cpp/gdal_unit_test.app/gdal_unit_test] Error 1
> make[1]: *** [autotest/cpp/CMakeFiles/gdal_unit_test.dir/all] Error 2
> make: *** [all] Error 2
>> On 12 Nov 2022, at 12:45 pm, Even Rouault <even.rouault at spatialys.com> wrote:
>> Weird. So it would seem the SQLite3 build on iOS lacks sqlite3_progress_handler()
>> As this is not critical for operations, I've added a CMake configure check for the presence of this function to conditionally enable it.
>> Can you try https://github.com/OSGeo/gdal/pull/6675 ?
>> Even
>> Le 12/11/2022 à 02:32, Nik Sands a écrit :
>>> After patching GDAL 3.6.0 for ‘pread64’ issue when building for iOS (see previous email), the build now progresses to the 100% mark, but then fails with the _sqlite3_progress_handler error below.
>>> I’m afraid that I don’t even know where to start with this one.  How should I proceed?
>>> Cheers,
>>> Nik.
>>> [100%] Built target check_swq_parser_md5
>>> Consolidate compiler generated dependencies of target my_test_sqlite3_ext
>>> [100%] Built target my_test_sqlite3_ext
>>> [100%] Built target check_ods_formula_parser_md5
>>> Consolidate compiler generated dependencies of target test_gdal_fuzzer
>>> [100%] Linking CXX executable test_gdal_fuzzer.app/test_gdal_fuzzer
>>> make[2]: *** [fuzzers/tests/test_gdal_fuzzer.app/test_gdal_fuzzer] Error 1
>>> make[1]: *** [fuzzers/tests/CMakeFiles/test_gdal_fuzzer.dir/all] Error 2
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
> NIK SANDS
> Line Tamer | Time Traveller | Space Cadet
NIK SANDS
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221112/29797ea1/attachment-0001.htm>
