[gdal-dev] A CSW query that seems to me works badly
Even Rouault even.rouault at spatialys.com
Tue Nov 15 14:51:19 PST 2022
Add --debug on . You will get only the requests. The answers aren't logged.
Le 15/11/2022 à 23:47, andy a écrit :
> Ho Evan,
> how can I get that log?
> If I remove "-al" I have 0 results.
> But I do not understand why
> Il mar 15 nov 2022, 23:21 Even Rouault <even.rouault at spatialys.com> ha
> scritto:
>     Andrea,
>     It seems to me that the server ignores the filter, which is likely
>     a bug given that its GetCapabilies response includes a
>     <ogc:ComparisonOperator>Like</ogc:ComparisonOperator>.
>     Looking at GDAL logs, it emits a request equivalent to
>     $ curl -X POST -H "Content-Type: application/xml; charset=UTF-8"
>     -d '<?xml version="1.0" encoding="UTF-8"?><csw:GetRecords
>     resultType="hits" service="CSW" version="2.0.2"
>     xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
>     <http://www.opengis.net/cat/csw/2.0.2>
>     xmlns:gml="http://www.opengis.net/gml"
>     <http://www.opengis.net/gml>
>     xmlns:dc="http://purl.org/dc/elements/1.1/"
>     <http://purl.org/dc/elements/1.1/>
>     xmlns:dct="http://purl.org/dc/terms/" <http://purl.org/dc/terms/>
>     xmlns:ogc="http://www.opengis.net/ogc"
>     <http://www.opengis.net/ogc>
>     xmlns:ows="http://www.opengis.net/ows"
>     <http://www.opengis.net/ows>
>     xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>     <http://www.w3.org/2001/XMLSchema-instance>
>     xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
>     http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"
>     <http://www.opengis.net/cat/csw/2.0.2http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd>><csw:Query
>     typeNames="csw:Record"><csw:ElementSetName>full</csw:ElementSetName><csw:Constraint
>     version="1.1.0"><ogc:Filter><ogc:PropertyIsLike wildCard="*"
>     singleChar="_" escapeChar="X"
>     matchCase="true"><ogc:PropertyName>dc:subject</ogc:PropertyName><ogc:Literal>Impianti
>     e strutture
>     ricettive</ogc:Literal></ogc:PropertyIsLike></ogc:Filter></csw:Constraint></csw:Query></csw:GetRecords>'
>     https://geodati.gov.it/RNDT/csw
>     which includes the filter specified in -where, but the server answers:
>     <?xml version="1.0" encoding="UTF-8"?><csw:GetRecordsResponse
>     xmlns:dcmiBox="http://dublincore.org/documents/2000/07/11/dcmi-box/"
>     <http://dublincore.org/documents/2000/07/11/dcmi-box/>
>     xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>     <http://www.w3.org/2001/XMLSchema>>
>     <csw:SearchStatus timestamp="2022-11-15T23:19:01+01:00"/>
>     <csw:SearchResults elementSet="full" nextRecord="1"
>     numberOfRecordsMatched="22" numberOfRecordsReturned="0"
>     recordSchema="http://www.opengis.net/cat/csw/2.0.2"
>     <http://www.opengis.net/cat/csw/2.0.2>/>
>     Even
>     Le 15/11/2022 à 23:00, andy a écrit :
>>     Hi,
>>     if I run
>>     ogrinfo -ro -al "CSW:http://geodati.gov.it/RNDT/csw" -where
>>     "subject LIKE 'Impianti e strutture ricettive'"
>>     I have 22 items in the result. But no one of those have in the
>>     subject the string "'Impianti e strutture ricettive".
>>     Why don't I have zero results?
>>     Thank you
>>     Andrea Borruso
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221115/6b80eb20/attachment.htm>
