[gdal-dev] A CSW query that seems to me works badly
Even Rouault even.rouault at spatialys.com
Wed Nov 16 02:51:27 PST 2022
> I need to run a CSW query using exact strings.
> Via curl it's in this way '<ogc:Literal>"Impianti e strutture
> ricettive"</ogc:Literal>' (using the double quotes inside):
hum, well you actually hit a bug in the OGR OGC Filter code I've just
fixed per https://github.com/OSGeo/gdal/pull/6713
With the fix the query sent is now:
HTTP: These POSTFIELDS were sent:<?xml version="1.0"
encoding="UTF-8"?><csw:GetRecords resultType="results" service="CSW"
version="2.0.2" startPosition="1" maxRecords="500"
xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:gml="http://www.opengis.net/gml"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"><csw:Query
typeNames="csw:Record"><csw:ElementSetName>full</csw:ElementSetName><csw:Constraint
version="1.1.0"><ogc:Filter><ogc:PropertyIsLike wildCard='*'
singleChar='_' escapeChar='!'
matchCase='true'><ogc:PropertyName>dct:abstract</ogc:PropertyName><ogc:Literal>"Impianti
e strutture
ricettive"</ogc:Literal></ogc:PropertyIsLike></ogc:Filter></csw:Constraint></csw:Query></csw:GetRecords>
That returns zero feature. That said, I'm not sure that is what you want
to do, since the server should really look for a dc:subject whose value
is "Impianti e strutture ricettive", with the double quotes.
Probably -where "abstract = 'Impianti e strutture ricettive'"  is more
what you want. But that returns also 0 features
Even
http://www.spatialys.com
